casperh wrote on Monday, January 14, 2013:
Hello
Controller: Atmel UC3A0512
Enviroment: ARV32 Studio
I have a USART interrupt which is like this:
__attribute__((__interrupt__)) static void usart_int_handler( void )
static int status, temp;
static uint8_t data;
static portBASE_TYPE xHigherPriorityTaskWoken;
// Read USART buffer
status = usart_read_char( USART_CHANNEL, &temp );
if( USART_RX_ERROR == status)
// Resetting the USART
usart_reset( USART_CHANNEL );
// Enable the USART as RS485
InitCOM();
else if( USART_SUCCESS == status )
data = (uint8_t)temp;
// Because FreeRTOS is not supposed to run with nested interrupts, put all OS calls in a critical section
portENTER_CRITICAL();
xQueueSendToBackFromISR( xRXQueue, &data, &xHigherPriorityTaskWoken );
portEXIT_CRITICAL();
if( xHigherPriorityTaskWoken == pdTRUE )
// Force unblocked (higher priority) tasks to run
vTaskSwitchContext();
I’m running in multidrop mode and I have 2 slave modules connected to this RS485 bus.
My problem is that when my task, which is looking at this xRXQueue, is seeing data in the queue and starts to read the queue, the system breaks down and restarts do to my watchdog. The task starts like this:
if( pdPASS == xQueueReceive(xRXQueue, rx_buf, portMAX_DELAY) )
// code here
How can I, in a more secure way, handle this queue and interrupt handling so it will not stall the controller?
Best regards
Casper
