darukur wrote on Monday, May 26, 2008:
Is valid for FreeRtoS project to modify the port.c file?
I’m using at the moment the PIC18F port.
I’m asking that because I have developments that needs a different SW/HW config and the provided for the port assumes that I need to use Serial communication and the CCP1 for Tick generation.
If I want to use as example Timer 0 for Tick generation and no serial com (e.g.:maybe I need the pins for other stuff) is licit to modify it? or there’s a way to get around it?
Best Regards.
