Is R9A06G043GBG#AC0 processor of Renesas which is using Arm® Cortex®-R4 Processor supported by freeRTOS?
Hello @bijugeorge ,
You should be able to use or refer to port here -FreeRTOS-Kernel/portable/GCC/ARM_CRx_No_GIC at main · FreeRTOS/FreeRTOS-Kernel · GitHub
Documentation with example is here - FreeRTOS running on the RZ/T (ARM Cortex-R4F) microprocessor from Renesas
