Dear All,
Is LM3S3749 microcontroller supported by FreeRTOS ?
what are the features supported and limitations of FreeRTOS with respect to LM3S3749
Does it also support USB interface of LM3S749
The kernel only uses the NVIC and SysTick, both of which are part of the Cortex M3 core itself, so FreeRTOS will run on any M3 from any manufacturer. You need only ensure the linker script is right for the memory map of your device.
