Hi folks:
Is it a mandator rule that a task must call “vTaskDelete” to delete itself ? what would happen
if a task just return without call vTaskDelete?
thank you!
Yes, it is mandatory, hence a rule, hence it is in the documentation. Try to see what happens if you don’t
Actually, in some ports, if you don’t delete the task and instead just run off the end of its implementing function you will end up in a function called something like “TaskDeleteError()” (forget the real name), that just hits an assert() so the application writer knows and can read the comment there.
thank you very much!
