nobody wrote on Thursday, March 09, 2006:
I’m using the HDLC IRQ of the STR710.
In this IRQ I’m putting all the data in the queue with :
HDLC_IRQHandler()
xTaskWokenByPost = pdFALSE;
while(there is data)
xTaskWokenByPost = xQueueSendFromISR( xRxQueue, &data, xTaskWokenByPost );
if( xTaskWokenByPost )
taskYIELD();
It means that we switch context and the task which is waiting for data in the queue will wake up. But how do we clear the pending HDLC bit IRQ in the EIC if this is done after the taskYIELD?
When there is a HDLC IRQ :
- IRQHandler is called
- HDLCIRQHandler is called
- HDLC_IRQHandler() is called
- ReturnAddress is called where the Clear pending bit in EIC is done but it will never be called because we switch context before.
crt0.s :
IRQ_Addr : .long IRQHandler
HDLC_Addr : .long HDLCIRQHandler
IRQHandler:
SUB lr,lr,#4
/*; Update the link register*/
SaveContext r0,r12
/*; Save the workspace plus the current*/
/* return address lr_ irq and spsr_irq.*/
LDR lr, =ReturnAddress
/*; Read the return address.*/
LDR r0, =EIC_BASE
LDR r1, =IVR_OFFSET
ADD pc,r0,r1
/*; Branch to the IRQ handler:HDLCIRQHandler*/
ReturnAddress:
/*Clear pending bit in EIC (using IPRx)*/
LDR r0, =EIC_BASE
LDR r2, [r0, #CICR_OFFSET]
/*; Get the IRQ channel number.*/
MOV r3,#1
MOV r3,r3,LSL r2
STR r3,[r0, #IPR_OFFSET]
/* ; Clear the corresponding IPR bit.*/
RestoreContext r0,r12
/*; Restore the context and return to the…
/* ; …program execution. */
HDLCIRQHandler:
IRQ_to_SYS
BL HDLC_IRQHandler
SYS_to_IRQ
I would like to know what is really happening with the switch context in the IRQ? ReturnAddress is called? How can we clear the HDLC IRQ?
Thanks
