Iot_mqtt Ping Request memory leak?
FreeRTOS MQTT V2.3.1 with IOT_STATIC_MEMORY_ONLY == 0
On mqttConnect(), _IotMqtt_pingreqSerializeWrapper() calls IotMqtt_MallocMessage() which is pvPortMalloc() in iot_config_common.h, allocating 2 bytes.
On mqttDisconnect(), _IotMqtt_FreePacket() claims
/* Don’t call free on DISCONNECT and PINGREQ; those are allocated from static memory. */
Am I missing something or is this a bug?
Thanks
W
Hi @wrm,
Thank you for bringing this to our attention, this is does look like a memory leak as that memory should be freed. I have created a pull request to address this.
Please let us know if you have any further questions.
Thank you
