Hi all,
the I2S write bytes or I2S write data got compiling error, so changed as I2S write OK, but got error as title at L93 of I2S_setting.h.
code of the I2S_setting.has below and the whole link: [ESP32 | Walkie-Talkie, Half-duplex communication based on WebSocket - from youtube, that I can’t link here now.
thanks.
#define I2S_WS_TX 12
#define I2S_SCK_TX 13
#define I2S_DATA_OUT_TX 15
#define I2S_PORT_TX I2S_NUM_0
#define I2S_WS_RX 33
#define I2S_SCK_RX 25
#define I2S_SD_RX 26
#define I2S_PORT_RX I2S_NUM_1
#define I2S_SAMPLE_RATE (16000)
#define I2S_SAMPLE_BITS (32)
#define I2S_READ_LEN (1024)
char* i2s_read_buff;
uint8_t* flash_write_buff;
const i2s_config_t i2s_config_tx = {
.mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_TX),
.sample_rate = I2S_SAMPLE_RATE,
.bits_per_sample = i2s_bits_per_sample_t(I2S_SAMPLE_BITS),
.channel_format = I2S_CHANNEL_FMT_ONLY_LEFT,
.communication_format = i2s_comm_format_t(I2S_COMM_FORMAT_I2S | I2S_COMM_FORMAT_I2S_MSB),
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 32,
.dma_buf_len = 64
const i2s_pin_config_t pin_config_tx = {
.bck_io_num = I2S_SCK_TX,
.ws_io_num = I2S_WS_TX,
.data_out_num = I2S_DATA_OUT_TX,
.data_in_num = I2S_PIN_NO_CHANGE
const i2s_config_t i2s_config_rx = {
.mode = i2s_mode_t(I2S_MODE_MASTER | I2S_MODE_RX),
.dma_buf_len = 64
const i2s_pin_config_t pin_config_rx = {
.bck_io_num = I2S_SCK_RX,
.ws_io_num = I2S_WS_RX,
.data_out_num = I2S_PIN_NO_CHANGE,
.data_in_num = I2S_SD_RX
void i2s_RX_init(){
i2s_driver_install(I2S_PORT_RX, &i2s_config_rx, 0, NULL);
i2s_set_pin(I2S_PORT_RX, &pin_config_rx);
void i2s_RX_uninst(){
i2s_driver_uninstall(I2S_PORT_RX);
void i2s_TX_init(){
i2s_driver_install(I2S_PORT_TX, &i2s_config_tx, 0, NULL);
i2s_set_pin(I2S_PORT_TX, &pin_config_tx);
void i2s_TX_uninst(){
i2s_driver_uninstall(I2S_PORT_TX);
void i2s_adc_data_scale(uint8_t * d_buff, uint8_t* s_buff, uint32_t len){
uint32_t j = 0;
uint32_t dac_value = 0;
for (int i = 0; i < len; i += 2) {
dac_value = ((((uint16_t) (s_buff[i + 1] & 0xf) << 8) | ((s_buff[i + 0]))));
d_buff[j++] = 0;
d_buff[j++] = dac_value * 256 / 1024 ;
void i2s_read_data(){
size_t bytes_read;
i2s_read(I2S_PORT_RX, (void*) i2s_read_buff, I2S_READ_LEN, &bytes_read, portMAX_DELAY);
i2s_adc_data_scale(flash_write_buff, (uint8_t*)i2s_read_buff, I2S_READ_LEN);
void i2s_write_data(char *buf_ptr, int buf_size){
//// i2s_write_bytes(I2S_PORT_TX, buf_ptr, buf_size, portMAX_DELAY); /// got compiling error: 'i2s_write_bytes' was not declared in this scope
// https://github.com/earlephilhower/ESP8266Audio/issues/273 // i change i2s_write_bytes to i2s_write and work properly
i2s_write(I2S_PORT_TX, buf_ptr, buf_size, portMAX_DELAY);
void i2s_buff_init(){
i2s_read_buff = (char*) calloc(I2S_READ_LEN, sizeof(char));
flash_write_buff = (uint8_t*) calloc(I2S_READ_LEN, sizeof(char));
