I downloaded the latest release, 7.3.0, and while trying to work with the LPC1114 example for the LPCXpresso toolchain, my little application hanged at the SVC_Handler handler interrupt.
After digging into the source code I found that changing this line
No, it comes about because CodeRed did not have the correct CMSIS names for their default handlers, so the names in their default vector tables was different.
SVC_Handler is the standard name, so it looks like CodeRed have changed their code.
