I’m new to embedded OSs and was curious how interrupts work in FreeRTOS. For example, when I receive a message via the UART peripheral and an interrupt occurs, how do I tell FreeRTOS what task to execute to handle that?
I went through my demo, everything worked great, and I read through the website but have not found a page devoted to explaining how interrupts work as far as starting up a specific task. Can you be more specific as to where I can find this?
You didn’t post your platform information (at least, not in this thread) so I can’t be more specific, but:
In FreeRTOS, you frequently set up an ordinary task (maybe with a high priority) to handle interrupts. This task spends most of its time sleeping while waiting for a semaphore to be tickled. When an interrupt occurs, the low-level ISR does any work that must happen immediately and then tickles the semaphore. The task wakes up and does whatever else is necessary.
In my code, I have the ISR disable the interrupt at issue, and then the interrupt-handling task re-enables it when everything has been taken care of. I think this is a common way of doing things.
So, to directly answer your question: you don’t have to tell FreeRTOS anything about which task goes with which interrupt. You just set up a semaphore, and have one task that sleeps on it, and an ISR that tickles it. (You could have multiple ticklers if you want, and maybe even multiple sleepers.) There’s nothing special about the ISR-to-interrupt-handler communication that’s any different from any other task-to-task communication. (Except, possibly, that certain FreeRTOS functions can’t be called from the ISR. You can only call functions whose names end in “_fromISR”)
This is for the AVR. So what you are saying is that I setup an ISR like I’d usually do without an OS, disable all interrupts, for the UART example do a quick read and copy to an array, and then have a high priority task that will handle the newly modified array after the ISR is completed, correct?
in free tos it is different. However, i found a niffy library that helps in terms of doing anything on the ARM (lib_AT91SAM7S64.h) ***google it*****
Pretty much, alot of stand routines of setting up the mcu is reference in that API.
