areeg wrote on Friday, April 05, 2019:
I’m trying to interface 6 ultrasoinc sesnors with Tiva C launch pad using FreeRTOS this code is working for only onw sensor but I have some problems when I add more than one I get wrong readings and sometimes when connecting 2 sensors they return the same value
#include "FreeRTOS.h"
#include "task.h"
#include "UART.h"
#include "Ultrasoinc_2.h"
unsigned long Reading1=0;
TaskHandle_t Ultrasonic_ReadingHandle=NULL;
TaskHandle_t Utrasoinc_InterruptHandle=NULL;
// Task to send Trigger Every 20 ms
void Ultrasonic_Trigger( void * pvParameters )
TickType_t xLastWakeTime;
while(1)
// Enable interrupt on PB0 pin connected to ultrasonic Echo
GPIO_PORTB_IM_R|=(1<<0);
// Makes trigger pin high for 10 us then low to send trigger to ultrasonic
Send_Trigger(1);
xLastWakeTime = xTaskGetTickCount();
vTaskDelayUntil(&xLastWakeTime,20);
// Task Resumed from External interrupt at Port B
/* At first Echo Flag is low , get the time of rising edge on PB0 , the next time to enter the task echo flag is high ,
* get time of falling edge and calculate the difference to get the distance measured
void Ultrasoinc_Interrupt_B( void * pvParameters )
TickType_t Start;
for( ;; )
taskENTER_CRITICAL();
if (!Echo)
// Get rising Edge time
Start=xTaskGetTickCount();
Echo=1;
Echo=0;
// Difference between rising and falling edges
pulse = (unsigned long)((xTaskGetTickCount()-Start)*170/100);
Delay_us(100);
Reading1=pulse;
taskEXIT_CRITICAL();
vTaskSuspend(NULL);
int main(void)
xTaskCreate(Ultrasoinc_Interrupt_B,"Utrasoinc_Interrupt",150,NULL,1,&Utrasoinc_InterruptHandle);
xTaskCreate(Ultrasonic_Trigger,"Ultrasonic_Reading",150,NULL,2,&Ultrasonic_ReadingHandle);
// Enable system clock
SYSCTL_RCGCGPIO_R|=(1<<0);
SYSCTL_RCGCGPIO_R|=(1<<1);
SYSCTL_RCGCGPIO_R|=(1<<4);
// Initialize UART
UART0_Init(9600,16000000);
// Make Trigger pin output and Echo pin input and enable interrupts in echo pin
Configure_Echo();
Configure_Trigger();
// NVIC register
Enable_Ultrasionc_Interrupts();
vTaskStartScheduler();
while(1)
// External interrupt ISR
void Ultrasonic_PortB_Interrupt()
// Clear Flag
GPIO_PORTB_ICR_R|= (1<<0);
// Resume handling Task
BaseType_t check;
check = xTaskResumeFromISR(Utrasoinc_InterruptHandle);
portYIELD_FROM_ISR(check);
I don’t know how to read more than one sensor, as the task handling the interrupt is resumed from ISR so each sensor gives an interrupt enters the same task and I can’t determine the echo is comming from which sensor.
Is it better to have separate tasks to send trigger for each sensor?
Thanks
