Hi. I’m trying to come up with a robust design for inter-core communications and have a question that I haven’t seen asked or answered yet here.
I found multiple sources both in the official documentation as well as threads here suggesting that I could use stream buffers or message buffers for safe communications between two processor cores via shared memory, provided that there is only a single reader and a single writer.
My situation is that I have a dual core processor, with one core running FreeRTOS and the other running on bare metal in a super loop with a dispatcher.
The question that I have is, can I still use stream buffers and/or message buffers for communications with that other core, provided the following:
- Ensure that the buffers are initialized before the non-RTOS core accesses them.
- For code calling from the non-RTOS core, modify the code to ensure that there are no kernel calls. This will be simplified somewhat, since I’m not planning to do anything other than send/receive, with a timeout that is always 0.
Will this work, or am I better off implementing an asymmetric multiprocessing architecture? I should note that the MCU vendor does not have good support for AMP, so this would not be a trivial undertaking.
Aside from the above, are there any other strategies worth considering?
