ghadadhibi wrote on Thursday, December 29, 2016:
I’m woking with STM32L486RG MCU using IAR v7.4 IDE.
In my poject , I’m required to implement an FTP server on my **SD card **using the FreeRTOS+ library.
For the internet connection , I’m using the WINC1500 module of ATMEL.
When I started the integration of the FreeRTOS +, I found that there are files called “FreeRTOS_sockets.c” and "FreeRTOS_sockets.h" and I start to be a little bit confused whether these files use my** WINC1500 socket** or they use and create another socket type.
Currently in my project, I have an MQTT client implemented and it uses the WINC1500 socket. So, if I want to implement the FTP server , should I use the some socket of my WINC1500 module or let the FreeRTOS_sockets files use their own ?
Sorry , but I’m in urgent need for help because I’m getting lost and I don’t really find enough information about this issue on the net.
Thanks in advance !
