system
(system)
November 18, 2008, 8:54am
1
wella wrote on Tuesday, November 18, 2008 :
is there a different method to measure time (with logic analyzer, pin L/H) how long FRTOS stays in the idleTask?
I have tried trace macros
traceTASK_SWITCHED_IN()
if (0 == strcmp(pxCurrentTCB->pcTaskName, "IDLE")) …
traceTASK_SWITCHED_OUT()
but it is a little uncomfortably to compare 5 bytes and call library function.
Thanks
Martin
system
(system)
November 18, 2008, 9:25am
2
davedoors wrote on Tuesday, November 18, 2008 :
The idle task is automatically created when the scheduler is started. If you create all your tasks before the scheduler starts, and never delete any tasks, then you can use
if( (uxCurrentNumberOfTasks - 1) == pxCurrentTCB->uxTCBNumber )
but configUSE_TRACE_FACILITY must be set to 1.
Another way is to store a handle to the idle. Assuming you store this in a variable called xIdleTaskHandle then you can do
if( pxCurrentTCB == xIdleTaskHandle )
system
(system)
November 18, 2008, 11:11am
3
Yes,
the first solution seems fine.
How to store xIdleTaskHandle? In vTaskStartScheduler() is called xTaskCreate( prvIdleTask, ( signed portCHAR * ) "IDLE", tskIDLE_STACK_SIZE, ( void * ) NULL, tskIDLE_PRIORITY, ( xTaskHandle * ) NULL ); so I think that I should create vApplicationIdleHook(), call xTaskGetCurrentTaskHandle() in it and store to global variable?
Thank You
Martin
system
(system)
November 18, 2008, 11:14am
4
That would work, but you could just edit the call to
as
xTaskCreate( prvIdleTask, ( signed portCHAR * ) "IDLE", tskIDLE_STACK_SIZE, ( void * ) NULL, tskIDLE_PRIORITY, &xIdleTaskHandle );
just the last parameter is different.
system
(system)
November 18, 2008, 4:35pm
5
Ok, I only wanted to avoid editing source code of FT(task.c).
Many thanks that you noticed configUSE_TRACE_FACILITY option. I was confused, why it don’t work before reading third paragraph :).
Martin
