jakbird wrote on Thursday, October 04, 2007:
Is there a specific global inside the RTOS where a crash handler for ARM aborts can identify which task was active when the exception occurred? Since this is a crash situation I don;t want to make any RTOS calls. The specific situation I’m trying to trace is where code jumps to non-existent memory, causing an ARM prefetch abort. The link address for the exception only tells me the bad address, not where the real error is located.
Jack Peacock
