#include <iostream>
#include <streambuf>
#include <stdexcept>
#include "FreeRTOS.h"
#include "stream_buffer.h"
class FreeRTOSStreamBuffer : public std::streambuf {
public:
FreeRTOSStreamBuffer(size_t bufferSize) {
// Create the FreeRTOS stream buffer
xStreamBuffer = xStreamBufferCreate(bufferSize, 1);
if (xStreamBuffer == nullptr) {
throw std::runtime_error("Failed to create FreeRTOS stream buffer");
~FreeRTOSStreamBuffer() {
vStreamBufferDelete(xStreamBuffer);
protected:
virtual int_type overflow(int_type c) override {
if (c != EOF) {
char z = c;
if (xStreamBufferSend(xStreamBuffer, &z, 1, portMAX_DELAY) != 1) {
return EOF;
return c;
virtual std::streamsize xsputn(const char* s, std::streamsize n) override {
return xStreamBufferSend(xStreamBuffer, s, n, portMAX_DELAY);
private:
StreamBufferHandle_t xStreamBuffer;
int main() {
// Create an instance of FreeRTOSStreamBuffer
FreeRTOSStreamBuffer myStreamBuffer(1024); // Size of the stream buffer
// Set the custom stream buffer for std::cout
std::cout.rdbuf(&myStreamBuffer);
// Now you can use std::cout as usual
std::cout << "Hello, FreeRTOS Stream Buffer!" << std::endl;
return 0;
my class gives me an error when I try to inherent public std::streambuf. it goes into trap
I have enabled
#define configSUPPORT_DYNAMIC_ALLOCATION 1
#define configUSE_STREAM_BUFFERS 1
#define configUSE_NEWLIB_REENTRANT 1
