how to use vTaskStartScheduler() with portUSE_PREEMPTION as parameter
manish9161 wrote on Tuesday, July 08, 2014:
Hello I am working with stm32f3Discovery with FreeRTOS .I have created task with various priorities.I have to schedule that task in preemptive scheduling algorithum.
so I have added
1.#define portUSE_PREEMPTION 1 in portmacro.h
and pass to vTaskStartScheduler(portUSE_PREEMPTION)
But code isn’t compiled because vTaskStartScheduler(void ) in task.c
so how should i use preemptive scheduling algorithum…?
my code
#include "FreeRTOS.h"
#include "task.h"
#include "stm32f3_discovery.h"
#include
#include
 *    \fn          init()
 *    \brief       LED init function
 *     \param	    -
 *     \return      -
void init()
   STM_EVAL_LEDInit(LED3 | LED4 | LED5 | LED6 );
 *    \fn          void TaskA()
 *    \brief       taskA callback function
void TaskA()
 	 for(uint8_t i= 0; i< 10 ; i++)
    	  STM_EVAL_LEDOn(LED3);
    	  vTaskDelay(10);
    	  STM_EVAL_LEDOff(LED3);
 *    \fn          void TaskB()
 *    \brief       taskB callback function
void TaskB()
	      STM_EVAL_LEDOn(LED4);
	      vTaskDelay(10);
	      STM_EVAL_LEDOff(LED4);
 *    \fn          void TaskC()
 *    \brief       taskC callback function
void TaskC()
   	   STM_EVAL_LEDOn(LED5);
   	   vTaskDelay(10);
   	   STM_EVAL_LEDOff(LED5);
 *    \fn          void TaskD()
 *    \brief       taskD callback function
void TaskD()
      STM_EVAL_LEDOn(LED6);
      vTaskDelay(10);
      STM_EVAL_LEDOff(LED6);
 *    \fn       main()
 *    \brief     main function
int main(void) {
init();
/*! TaskA is having highest priority */
xTaskCreate(TaskA, (signed char*)"TaskA", 128, NULL, configMAX_PRIORITIES, NULL);
/*! TaskB having medium priority */
xTaskCreate(TaskB, (signed char*)"TaskB", 128, NULL, tskIDLE_PRIORITY+2, NULL);
/*! TaskC ,and TaskD  Idle tasks */
xTaskCreate(TaskC, (signed char*)"TaskC", 128, NULL, tskIDLE_PRIORITY, NULL);
xTaskCreate(TaskD, (signed char*)"TaskD", 128, NULL, tskIDLE_PRIORITY, NULL);
vTaskStartScheduler(portUSE_PREEMPTION);
return 0;
rtel wrote on Tuesday, July 08, 2014:
Please refer to the online documentation and the many hundreds of pre-configured examples that are provided for you to use and reference.
I’m not sure where you got the idea that you had to pass a parameter into vTaskStartScheduler(), because as you have said yourself the prototype for the function is void, and the online API documentation for the function shows it as a void function, and the example on the API documentation page showing you how to use the function does not show it taking a parameter, neither does any of the examples provided in the download.
http://www.freertos.org/FreeRTOS-quick-start-guide.html
http://www.freertos.org/a00132.html
http://www.freertos.org/a00110.html#configUSE_PREEMPTION
Please also note that all your task definitions are wrong too, so even if you start the scheduler using the correct semantics, you will end up in an assert() when the task attempts to exit without calling vTaskDelete( NULL ). Again all this information is provided for you…
manish9161 wrote on Wednesday, July 09, 2014:
Thanks a lot for your valuable response.I have modified my code as per your suggestions.Now its working fine just I have to test it.
