nobody wrote on Monday, January 23, 2006:
hi,
How can understand when the stack of a process is too little?
In other words, At run time, how can I understand if the stack is full or near to be full?
Thanks!!
hi,
Thanks!!
rtel wrote on Monday, January 23, 2006:
The stack is filled with 0xa5 when the task is created. In the debugger you can inspect the stack and see how much remains at 0xa5 which will show you the high water mark.
There is also a function usTaskCheckFreeStackSpace(), although this leaves interrupts disabled for a while and is not good to use in a production system.
The live WEB server demo’s use usTaskCheckFreeStackSpace to display the high water mark of each stack.
