I am working with a periodic Interrup in which i have inizialized a counter, every time i get an interrupt the counter is increased by one unit through a notification function. This notification function is executed in the ISR ( Interupt Service Rountine). Is there anyway that i can show that variation of this counter outside the ISR, say in my main.c file so that i can use it for a conditional trigger ( ex: " if ( counter == 50)")
thanks to all that might be able to help
A variable defined outside any function, is at file scope and is directly accessable by any function in that file, and by functions in other files in they have an ‘extern’ decleration for the variable, unless the definition was declared static.
You do need to make sure that the reading/changes are atomic (done without possible interruption) or you might get mixed results. You may need to also add a volatile to let the compiler know that this variable might change behind its back in the ISR, so it doesn’t ‘optimize’ the test to use a value it read previously, which might now be wrong.
Can you explain better what you mean by atomic ? my changes on this
variable happen in the ISR routine by it is a global variable and not
defined as static. But my main.c doesn’t seem to recognise the changes at
all. I know that my variable is increasing in the ISR because the reaching
of a certain value on that variable triggers an hardware action that I can
see. but I cannot use the variable change outside my function that runs in
the ISR.
Perhaps if you show the code you use. The only way that main.c won’t see the change in the variable is if main.c is seeing a dfferent variable (perhaps with the same name).
The atomic comment is that if the varable in question isn’t accessed in a single unbreakable instruction, then it is possible that the read gets part of an old value and part of a new value, giving a value that doesn’t match either of them.
Thank you all for your help, indeed declaring the variable as volatile was
necessary and also the fact that I initialised my counter variable as equal
to 0 from the beginning so that was all that was readable outside the
function. I used a support variable in order to check how my main counter
was changing and everything works fine. Thank you all again.
How to share a variable change throughout the main.c an the ISR
