Hi . Thanks for answering.
Sorry for the delay, I was solving some issues with the hardware design that was urgent.
I have an idea how to solve the question, first the RunShadowDemo and runDemoTask functions are defined like this:
int RunShadowDemo( bool awsIotMqttMode,const char * pIdentifier,void * pNetworkServerInfo,void * pNetworkCredentialInfo,const IotNetworkInterface_t * pNetworkInterface )
if( status == EXIT_SUCCESS )
/* Clear the Shadow document so that this demo starts with no existing
* Shadow. */
_clearShadowDocument( mqttConnection, pIdentifier, thingNameLength );
/* Send Shadow updates. */
status = _sendShadowUpdates( &deltaSemaphore,mqttConnection, pIdentifier, thingNameLength );
/******* Added by MCU manufacturer ******/
for(;;)
vTaskDelay(100);
/* Delete the Shadow document created by this demo to clean up. */
/* Disconnect the MQTT connection if it was established. */
if( connectionEstablished == true )
IotMqtt_Disconnect( mqttConnection, 0 );
/* Clean up libraries if they were initialized. */
if( librariesInitialized == true )
_cleanupDemo();
/* Destroy the delta semaphore if it was created. */
if( deltaSemaphoreCreated == true )
IotSemaphore_Destroy( &deltaSemaphore );
return status;
void runDemoTask( void * pArgument )
/* On FreeRTOS, credentials and server info are defined in a header
* and set by the initializers. */
IotLogInfo( "---------STARTING DEMO---------\n" );
status = _initialize( pContext );
IotLogInfo( "Successfully initialized the demo. Network type for the demo: %d", demoConnectedNetwork );
pNetworkInterface = AwsIotNetworkManager_GetNetworkInterface( demoConnectedNetwork );
pConnectionParams = AwsIotNetworkManager_GetConnectionParams( demoConnectedNetwork );
pCredentials = AwsIotNetworkManager_GetCredentials( demoConnectedNetwork );
/* Run the demo. */
status = pContext->demoFunction( true,clientcredentialIOT_THING_NAME,pConnectionParams,pCredentials,pNetworkInterface );
/* Log the demo status. */
/* DO NOT EDIT - This message is used in the test framework to
* determine whether or not the demo was successful. */
IotLogInfo( "Demo completed successfully." );
IotLogError( "Error running demo." );
_cleanup();
IotLogError( "Failed to initialize the demo. exiting..." );
/* DO NOT EDIT - This demo end marker is used in the test framework to
* determine the end of a demo. */
IotLogInfo( "-------DEMO FINISHED-------\n" );
It can be seen that in the RunShadowDemo function there is an infinite loop (for(;;)) with a delay. This is a modification that the MCU manufacturer made for an example, and that way the demo is always working. (As long as there is no error in the network).
What I can think of to do is in the runDemoTask function is to wrap the entire process in an infinite loop as indicated below:
for(;;) //infinite loop by me
/* Run the demo. */
_cleanup();
that way, if an error occurs, the process would start again as many times as necessary.
Do you think it is a good idea?
