paulgcoleman wrote on Monday, April 23, 2012:
I have a scenario whereby I want to reset the processor in response to a fatal error that my code cannot recover from. I’m using an Atmel UC3C with the framework which Atmel provides along with FreeRTOS 7.0.1.
Within the framework is a macro called ResetCPU which is shown at the end. It’s a bit convoluted but basically it just sets a load of registers and does a jump to the _start by setting the program counter to 0x80000000 i.e. the reset vector.
My problem is that it doesn’t work and seems to crash the system and I don’t understand why. FreeRTOS still seems to be running in the background.
I have a fatal error task which is blocked on a semaphore and when the semaphore is signalled I stop some software timers that I create and suspend all the tasks below the fatal error priority and then wait for a switch to open and close before resetting. If I leave out the code which checks the switch it seems to work correctly and reboots the system but when the switch code is in there it just seems to crash. I tried replacing the switch checking code with a delay and it seems that any delay less than about 700ms is okay but more than that and the system crashes.
I’m wondering if it’s something to do with supervisor modes or the like but I don’t know enough about the bowels of FreeRTOS to know where to start.
Has anobody had the same problem or know what else I can try?
Thanks, Paul.
#define Reset_CPU() \
__asm__ __volatile__ (\
“lddpc r9, 3f\n\t”\
“mfsr r8, %\n\t”\
“bfextu r8, r8, %, %\n\t”\
“cp.w r8, 0b001\n\t”\
“breq 0f\n\t”\
“sub r8, pc, $ - 1f\n\t”\
“pushm r8-r9\n\t”\
“rete\n”\
“0:\n\t”\
“mtsr %, r9\n”\
“1:\n\t”\
“mov r0, 0\n\t”\
“mov r1, 0\n\t”\
“mov r2, 0\n\t”\
“mov r3, 0\n\t”\
“mov r4, 0\n\t”\
“mov r5, 0\n\t”\
“mov r6, 0\n\t”\
“mov r7, 0\n\t”\
“mov r8, 0\n\t”\
“mov r9, 0\n\t”\
“mov r10, 0\n\t”\
“mov r11, 0\n\t”\
“mov r12, 0\n\t”\
“mov sp, 0\n\t”\
“stdsp sp, sp\n\t”\
“ldmts sp, sp\n\t”\
“mov lr, 0\n\t”\
“lddpc pc, 2f\n\t”\
“.balign 4\n”\
“2:\n\t”\
“.word 0x80000000\n”\
“3:\n\t”\
“.word %”\
: “i” (AVR32_SR),\
“i” (AVR32_SR_M_OFFSET),\
“i” (AVR32_SR_M_SIZE),\
“i” (AVR32_SR_GM_MASK | AVR32_SR_EM_MASK | (AVR32_SR_M_SUP << AVR32_SR_M_OFFSET))\
