I am using the STM32F103 with Freertos and I cannot remove some unused function from my executable, it costs some extra Kbytes of Flash.
I am using the compiler options -fdata-sections -ffunction-sections -Wl,–gc-sections -Os
to remove all the unused symbols but some Freertos functions like xQueueGenericSend are still there in my executable. That happens only for the FreeRTOS functions.
I am not using Queues in my software and I also changed the FreertosConfig.h file to deactivate some functionality but the unused FreeRTOS functions are still there, in my program.
Could you explain me how can I remove this unused functions?
The compiler options will place functions in separate sections. Are you then also using the linker options to remove unused sections? Note if you have configUSE_TIMERS set or if you are using semaphores then queues will be in use by the kernel.
ok, thank you for your reply. I am using the linker option -Wl,-gc-sections to remove the unused code. As you write, I think that the reason is that the functions are used in Semaphore.
As for the linker, I added the option -Wl,--gc-sections, note that is has a double-dash before --gc. It is passed to the linker. This is the complete command:
Another trick: can you temporarily disable compilation of the function xQueueGenericSend(), with an #if 0? The linker may then tell you which module is calling mentioned function.
Yes, FreeRTOS uses Queue functionality for a LOT of different purposes (Queue, Semaphores, and Mutexes, and Timers use a Queue) so you normally have the basic queue code loaded, but that code also supports a lot of functionality so you don’t need other code to support it.
