yyang2000 wrote on Wednesday, March 17, 2010:
Re: FreeRTOS v5.03 + uIP + Web Server
I have a question regarding the heap2 memory measurement in run time. I am suspecting my project has memory issue. The project has implemented a web server with uIP TCP stack that sometimes ran quickly to respond the request from web browse, but sometimes it stuck took longer to responding or timeout. Then I have to recycle the system power to restart.
I know the xPortGetFreeHeapSize() function call can measure memory size, but I wonder when and where it should be called in run time to measure the heap over size or not. Does it need to create a task for measuring? Any suggestion will be welcome.
By the way, I used heap2 with MAX size 24000 in definition.
Thanks,
Bill
