I want to know how to get uptime because xTaskGetTickCount() return an 32-bit unsigned int ?.. 32-bit is too small.
Is there a FreeRTOS function to do it ?
First - this is only an application issues - the kernel itself doesn’t
care that the timer overflows as that is handled internally. Many
applications, especially in the early years, used 16-bits tick values so
overflowed very regularly and many of our tests still use 16-bit ticks
to force that to happen.
Your application code on the other hand would have to handle this by
noticing that the tick count value had wrapped, and then act
appropriately. There is actually a variable in FreeRTOS/Source/tasks.c
called xNumOfOverflows which also counts the number of overflows, but it
is static so file scope. The functions vTaskSetTimeoutState() https://freertos.org/vTaskSetTimeOutState.html and
xTaskCheckForTimeOut() https://freertos.org/xTaskCheckForTimeOut.html do
make use of it though. If you wanted access yourself you could add a
‘get’ function to a header file called freertos_tasks_c_additions.h, and
then set configINCLUDE_FREERTOS_TASK_C_ADDITIONS_H to 1 in
FreeRTOSConfig.h to have the header file incldued at the bottom of
tasks.c. If you look at the code at the bottom of tasks.c you will see
the mechanism.
In addition - you would only need this to have a delay longer than 30
years - otherwise provided you maintain the time in unsigned variables
and formulate the tests on the time correctly overflows will result in
underflowed comparison results that will actually give you the right answer.
