Hi all,
This is my code ( port.c) to enter deepsleep mode with LPC54114. It enters well but can not wakeup. Could you share your solution suggestions?
/* Set the new reload value. */
RTC_SetWakeupCount(pxRtcBase, ulReloadValue);
/* Enable RTC. */
RTC_StartTimer(pxRtcBase);
/* Sleep until something happens. configPRE_SLEEP_PROCESSING() can
set its parameter to 0 to indicate that its implementation contains
its own wait for interrupt or wait for event instruction, and so wfi
should not be executed again. However, the original expected idle
time variable must remain unmodified, so a copy is taken. */
xModifiableIdleTime = xExpectedIdleTime;
configPRE_SLEEP_PROCESSING(xModifiableIdleTime);
if (xModifiableIdleTime > 0)
__DSB();
//__WFI();
POWER_EnterDeepSleep(0xF0000U);
__ISB();
configPOST_SLEEP_PROCESSING(xExpectedIdleTime);
