I am new to the FreeRTOS system and I need some delay to initializing a LCd display, but since it is only require a delay in nanosecond, then it seems a but overkill to use vTaskDelay in milisecond, but is it possible to make vTaskDelay to delay in nanoseconds? or is there another option? right now I use asm to create a delay.
VTaskDelay uses scheduler to make a delay. It means two things:
- delay time can be only a multiple of scheduler tick (usually multiple of 1ms)
- other tasks can run when the task is delayed.
To use scheduler for delay you have to check ready tasks list and (if necessary) switch context. All of this takes some time, for example approx 10us for ARM7TDMI running with 48MHz core clock.
The conclusion is that to make very small delays use the loop (as you are doing now), for bigger delays (more than lets say two scheduler tick) use VTaskDelay.
I forgot to add that if you need to do delay, which value is somewhere between 10us(task switching time) and 1ms(scheduler tick), you should use timer interrupts or get your hardware redesigned.
Try to use an asm("nop") loop strategy. Knowing the system clock you can obtain very little delays. It skips all the OS scheduling but you can obtain you low desired delay values.
Thanks for your replies.
I just assumed that using asm("nop") was a brutal way of doing things, but if that is your only option, I have to stick with that
It might seem brutal and wasteful but compared to two task switches (to another task and back again), wasting small amounts of time with NOPs is insignificant.
Depending on your microprocessor and its clock speed, some of the required delays may be shorter than a single instruction. Therefore it’s hard to get the timing optimal unless you use a logic analyser.
