ESP32.
However, for aws freertos, it seems I need a certificate (demo) to connect to wifi.
Please tell me how to do a simple wifi conecting and connecting to a local mqtt server.
The URL is below.
mqtt://localhost:1883
ESP32.
The URL is below.
This demo shows how to connect to a local MQTT broker unencrypted - FreeRTOS/FreeRTOS-Plus/Demo/coreMQTT_Windows_Simulator/MQTT_Plain_Text at main · FreeRTOS/FreeRTOS · GitHub
This is for Windows Simulator - you can use this as a reference and do the same on ESP32.
Thank you for your reply.
Where exactly is this described in this?
Have you seen the documentation here?
I have checked.
Thank you very much.
Can I refer specifically to “Subscribing to a MQTT Topic”?
Also, are there samples that actually connects to mqtt bloker on macbook localserver as aws freertos instead of freertos?
What do you mean by aws freertos? The example I mentioned above uses our MQTT client library to connect to MQTT broker which can very well be the broker running on your local laptop.
can I use that’s example you mentioned to connect mqtt bloker on macbook localserver?
is it for windows?
Yes, you can.
Yes, it is for windows. You can use this as a reference to do the same on any platform.
