toanthieu wrote on Friday, May 22, 2009:
Dear Sir/Madame
I just bought one Atmega128 evaluation board and I want to load the FreeRTOS5.11 to this board but I have a problem with demo for ATMEGA323 like this.
When I use IAR to open the demo project in ATMEGA323 and then I complile the source code. It is working well but when I plugged JTAGmkII to board for debuging and IAR inform "The stack plug-in failed to set a break point on "main". The stack window will not be able to display stack content (you can change this setting in Tools->Options dialog box) ".
Could you pleased show me why this error happen?
I also the change the configuration to ATMEGA128 by changing the library to iom128.h and change atmega device in option of project and I debug with JTAGmkII but It is not working too.
When I debugged, it always inform the stack pointer is outside.
This is the first time, I try with OS. Could you give me a help? Thank you so much.
Best regards
Toan Thieu
