soujanyabargavi wrote on Monday, November 26, 2018:
I have a 1 Master with 1 Slave Solr cluster in AWS. This is the Bitnami version of Solr. How do I go about adding a second Slave to this existing cluster?
In a regular Solr setup I would just fire off a new server, install Solr and change config to add the new instance but I’m not sure how to do this with the AWS Certified Bitnami setup as there seems to be some differences how it is setup from out-of-the-box Solr.
The Master/Slave setup is not in “cloud” mode.
