How the schedular behaves when all the task are of same priority?
I am new to FreeRTOS and trying to understand how the schedular works when all the created task have same priority.
will there be preemption? I mean one task can preempt the other one in the below code?
Just for better understanding of the problem i have included the source code as well
#include <Arduino_FreeRTOS.h>
#define YELLOW 6
#define GREEN  7
#define BLUE   8
#define SET(digitalPin) digitalWrite(digitalPin, HIGH)
#define RESET(digitalPin) digitalWrite(digitalPin, LOW)
#define TOGGLE(digitalPin) digitalWrite(digitalPin, digitalRead(digitalPin)^1)
typedef int taskProfiler;
taskProfiler yellowLedProfiler = 0;
taskProfiler greenLedProfiler = 0;
taskProfiler blueLedProfiler = 0;
void setup() {
  // put your setup code here, to run once:
  Serial.begin(115200);
  xTaskCreate(yellowLedControllerTask, "YellowLED",128,NULL,1,NULL);
  xTaskCreate(greenLedControllerTask, "greenLED",128,NULL,1,NULL);
  xTaskCreate(blueLedControllerTask, "blueLED",128,NULL,1,NULL);
void yellowLedControllerTask(void *pvParameters){
  pinMode(YELLOW, OUTPUT);
  while(1){
    SET(YELLOW);
    yellowLedProfiler++;
    Serial.print("YellowLedProfiler: ");Serial.println(yellowLedProfiler);
    RESET(YELLOW);
    delay(30);
void greenLedControllerTask(void *pvParameters){
  pinMode(GREEN, OUTPUT);
  while(1){
    SET(GREEN);
    greenLedProfiler++;
    Serial.print("greenLedProfiler: ");Serial.println(greenLedProfiler);
    RESET(GREEN);
    delay(30);
void blueLedControllerTask(void *pvParameters){
  pinMode(BLUE, OUTPUT);
  while(1){
    SET(BLUE);
    blueLedProfiler++;
    Serial.print("blueLedProfiler: ");Serial.println(blueLedProfiler);
    RESET(BLUE);
    delay(30);
void loop() {
The use of preemption is controlled by the configUSE_PREEMTION flag in FreeRTOSConfig.h
Note, the function loop becomes part of a task, so should include at least a delay.
I don’t know if the “delay” function does a “spin wait” or calls vTaskDelay, so I would avoid using it (unless you can confirm it calls FreeRTOS) and do actual blocking with vTaskDelay.
In addition to avoid trouble better define configASSERT and enable stack checking during development/debug builds.
The (minimal) task stacks are probably too small because you’re using stack hungry print functions in your task code.
Thanks for the response, it really helped me.
as far as i know, delay is implemented using timer0 function in arduino library and it does not depend on vTaskDelay() function of FreeRTOS.
Noted. I will try doing so.
And delays that work by just waiting (by busy-loop testing) for the time to pass do not provide for the multi-tasking that is desired with FreeRTOS.
