How long (cycles) is a yield on a Cortex-M0+?
ljskinny wrote on Thursday, May 11, 2017:
Hi all,
We have a strange problem in using a time critial interrupt (samplin input) in conjunction with the freeRTOS.
my first question is, how long a yield is, which uses the critical section and disables the global interrupts.
So this could be the reason for blocking the interrupt.
I would expect, that the yield should not block that long the interupt or i am i something missing?
Any ideas are welcome. I have to check, if the RTOS itself is the problem for the issues in our application.
Best regards
Holle
rtel wrote on Thursday, May 11, 2017:
If you are referring to the context switch time then you can find some
information for a Cortex-M3 on the link below. An M0 will be a bit
slower due to its more limited instruction set.
Also unlike an M3, the M0 will globally disable interrupts in a critical
section - do you have long critical sections?
(taskENTER_CRITICAL()/taskEXIT_CRITICAL)
http://www.freertos.org/FAQMem.html#ContextSwitchTime
