I do not have a standard work flow. To me the important thing is to find a good model for the project at hand. Some people swear by UML or compatible tools, but I find them too restrictive. I go through a lot of pencils, paper and brain cells to find a âBird eye viewâ control flow that looks like a fair approximation of the thing to realize. There is a lot of experience and intuition involved. Once I have a good feeling about it, I generally code upside down.
But that is my personal, very individual approach. Others come up with equally well working architectures through very different work flows.
I understand that you make models with pencil on paper for the project. Iâm curious to know what you draw in this model. if you have a sample model can you post it i would like to see it
My first step is to divide the project into the pieces that need to work together and to define what information they need to communicate/share. If the system has âMajor Stateâ (like a âStandbyâ state), that might show up here. The sequence of operations would tend not to show up at the top-level diagram.
Then each of these piece get defined with their inputs and outputs, and what they do in the middle. At this point I havenât even defined what operations are to be put into a âTaskâ and what are just operations that just happen âsomewhereâ (They might be subroutines the sending operation runs in its task space, and not a message that gets sent to a task In this operation task space.
Only at this point do I work on defining what are my tasks, and how various requests get into the task.
Note, sometimes several pieces get merged into a single task, if they are interrelated enough. Things like, first we do operation A, then we do operation B on the results, then we do operation C, might make more sense as a single task that does A, B, then C.
Sometimes an operation just becomes a function library that does the interaction. I/O is often a major case for this, Most I/O doesnât create a base task to handle it, but is just a library that doesnât use a task. âStatefulâ I/O like USB or Ethernet is a major exception, those tend to need a task to process them.
