Hello, I am using heap_5 to spread the heap between available internal and external memory. The sizes and locations are found with the linker file, and the definitions are done as so:
uint32_t heapSize = (uintptr_t)&__heap_limit_mp - (uintptr_t)&__heap_start_mp;
uint32_t heapSize3 = (uintptr_t)&__heap_limit_mp3 - (uintptr_t)&__heap_start_mp3;
HeapRegion_t heap_regions[] = {
{ (uint8_t*)&__heap_start_mp, heapSize }, // Remaining on chip RAM non-CCM
{ (uint8_t*)&__heap_start_mp3, heapSize3 }, // Remaining off chip PSRAM
{ NULL, 0 } };
vPortDefineHeapRegions( heap_regions );
I’m inconsistently hitting eitherconfigASSERT( heapBLOCK_IS_ALLOCATED( pxLink ) != 0 ); or configASSERT( pxLink->pxNextFreeBlock == NULL );, leading me to believe that the memory locations are being changed or overwritten, but there is nowhere in code that I am doing this, and I’ve checked for memory leaks. Sometimes, it also works without issue. Has anyone come across this or something similar and found a solution?
