Hi All.
I use 3 ISR: ECT for system tick counter, CAN and PIT timer.
I set priority:
PIT timer is 7 ( highest ),
CAN is 6,
ECT is 5 ( lowest ).
I want something to FreeRTOS don`t disable global interrupt, macros portENABLE_INTERRUPTS() I do empty.
After that, the program stops working, it crash.
Why? Ыo you can not do at all?
Best regards,
Sergey.
HCS12 only has one interrupt inhibit bit, so no nested interrupts. You *could* re-enable interrupts in the ISR, but this will enable *all* interrupts. To the extend that even a lower priority interrupt can occur. That’s usually not what you want.
So indeed: nested interrupts for HCS12 is not supported (by the hardware, and by the port).
The problem is that in highest priority PIT timer ISR managed hardware with period 25 us.
If I disabled global interrupt I get a bid jitter.
This is critical for my application.
Sergey.
