The call path as follows,
prvTimerTask->prvProcessTimerOrBlockTask → xTaskResumeAll → listREMOVE_ITEM( &( pxTCB->xEventListItem ) )
Any suggestions?
Any suggestions?
This likely is a memory corruption. Which hardware are you using? Have you tried common debugging techniques like defining configASSERT, enabling stack overflow checking etc. as described here - FreeRTOS - Open Source RTOS Kernel for small embedded systems
The demo has defined configASSERT and enabled stack overflow checking(2). but cannot detect the issue. It’s a ramdom issue within two hours stress test.
This also indicates towards some memory corruption. Try setting configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES to 1 in your FreeRTOSConfig.h.
Another thing to try is to turn off functionality off your application one by one to narrow down the problematic part.
Ok, got it. let me enable the config configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES to check it.
Please provide the following -
Hi Gaurav,
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#define configUSE_TICKLESS_IDLE 1
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ (SystemCoreClock)
#define configTICK_RATE_HZ ((TickType_t)1000)
#define configMAX_PRIORITIES (15)
#define configMINIMAL_STACK_SIZE ((unsigned short)256)
#define configTOTAL_HEAP_SIZE ((size_t)(40 * 1024))
#define configMAX_TASK_NAME_LEN (10)
#define configUSE_TRACE_FACILITY 0
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 0
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_MALLOC_FAILED_HOOK 1
#define configUSE_APPLICATION_TASK_TAG 0
#define configUSE_COUNTING_SEMAPHORES 1
#define configGENERATE_RUN_TIME_STATS 0
#define configUSE_TIME_SLICING 0
#define configUSE_LIST_DATA_INTEGRITY_CHECK_BYTES 1
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES (2)
/* Software timer definitions. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY (10)
#define configTIMER_QUEUE_LENGTH 10
#define configTIMER_TASK_STACK_DEPTH (configMINIMAL_STACK_SIZE * 2)
#define INCLUDE_vTaskPrioritySet 0
#define INCLUDE_uxTaskPriorityGet 0
#define INCLUDE_vTaskDelete 0
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 0
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTimerPendFunctionCall 1
#define taskDISABLE_INTERRUPTS() portDISABLE_INTERRUPTS()
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
#define configASSERT(x) \
if ((x) == 0) \
taskDISABLE_INTERRUPTS(); \
for (;;) \
#if defined(__ICCARM__)||defined(__CC_ARM)||defined(__GNUC__)
/* Clock manager provides in this variable system core clock frequency */
#include <stdint.h>
extern uint32_t SystemCoreClock;
#ifndef configENABLE_FPU
#define configENABLE_FPU 1
#ifndef configENABLE_MPU
#define configENABLE_MPU 0
#ifndef configENABLE_TRUSTZONE
#define configENABLE_TRUSTZONE 0
#ifndef configRUN_FREERTOS_SECURE_ONLY
#define configRUN_FREERTOS_SECURE_ONLY 1
/* Redefine: Mutex is needed for SRTM communication */
#undef configUSE_MUTEXES
#ifndef configTOTAL_HEAP_SIZE
/* Interrupt nesting behaviour configuration. Cortex-M specific. */
#ifdef __NVIC_PRIO_BITS
/* __BVIC_PRIO_BITS will be specified when CMSIS is being used. */
#define configPRIO_BITS __NVIC_PRIO_BITS
#else
#define configPRIO_BITS 3 /* 7 priority levels */
#define configSTACK_DEPTH_TYPE uint32_t
function. */
#define configLIBRARY_LOWEST_INTERRUPT_PRIORITY ((1U << (configPRIO_BITS)) - 1)
routine that makes calls to interrupt safe FreeRTOS API functions. DO NOT CALL
#define configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY 2
/* Interrupt priorities used by the kernel port layer itself. These are generic
#define configKERNEL_INTERRUPT_PRIORITY (configLIBRARY_LOWEST_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
#define configMAX_SYSCALL_INTERRUPT_PRIORITY (configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY << (8 - configPRIO_BITS))
/* Definitions that map the FreeRTOS port interrupt handlers to their CMSIS
standard names. */
#define vPortPendSVHandler PendSV_Handler
#define vPortSysTickHandler SysTick_Handler
Typical causes of what you see are the following:
What is the priority of DMA interrupt?
DMA interrput priority is 5
ok, let me check them again.
Hi Gaurav and RAc,
This is my analysis, any suggestions?
dma isr
xQueueGenericSendFromISR
xTaskRemoveFromEventList
listREMOVE_ITEM( &( pxUnblockedTCB->xEventListItem ) ); (currently xEventListItem.pvContainer == NULL)
listINSERT_END( &( xPendingReadyList ), &( pxUnblockedTCB->xEventListItem ) ); (add xEventListItem to xPendingReadyList)
ILDE Task/Timer Task
xTaskResumeAll
pxTCB = listGET_OWNER_OF_HEAD_ENTRY( ( &xPendingReadyList ) );
listREMOVE_ITEM( &( pxTCB->xEventListItem ) );
( pxList->uxNumberOfItems )-- /* hardfault in here(pxList is NULL, pxList is xEventListItem.pxContainer) */
It looks as if your dma isr is running on a priority hiher than max syscall yet uses FreeRTOS APIs. That is not allowed, even though the correct API set (xxxFromISR) is used.
Hi @RAc ,
The DMA isr’s priority is 5(not shifted, after shifted, the value is 0xA0).
configMAX_SYSCALL_INTERRUPT_PRIORITY is set to 0x40.
0x40 < 0xA0, so the priorify of dma is lower than max syscall?
That seems right. Can you try disabling the functionalities of your application one by one to narrow down the problematic part?
hi Gaurav,
ok, got it. Thanks.
