HardFault Error in Private Key Parsing with mbedTLS and FreeRTOS
Hi everyone,
I’m currently working on integrating mbedTLS with FreeRTOS in my project, using STM32CubeIDE as my development environment. However, I keep running into a HardFault error when trying to parse a private key using mbedTLS.
Here’s what I’ve observed:
  • When I use mbedTLS without FreeRTOS, everything works perfectly.
  • The issue arises only when FreeRTOS is included in the setup.
I suspect the issue could be related to one of the following:
  1. Task stack size?
  2. Heap management (e.g., memory allocation issues)?
  3. Any specific thread-safety considerations with mbedTLS?
I’ve attached a screenshot of the function call stack to provide more context. Please take a look—any guidance or suggestions would be greatly appreciated!
Thanks in advance!
When you use MbedTLS with FreeRTOS, you need to enable threading support in MbedTLS (by defining MBEDTLS_THREADING_C in mbedtls config file) and supply some platform functions. You can refer to the following -
Hi Gaurav,
I have made the changes you suggested, but I am still encountering the same error
Does not seem correct because the call to mbedtls_calloc should not go into _call0oc_r. Can you see why the call is not getting routed to here - FreeRTOS/FreeRTOS-Plus/VisualStudio_StaticProjects/MbedTLS/mbedtls_freertos_port.c at main · FreeRTOS/FreeRTOS · GitHub.
You likely need these lines in your mbedTLS config file.
