mindthomas wrote on Saturday, December 08, 2012:
Hi all.
I have never really been the RTOS guy but I have decided to give it a try now, especially because of the need of a proper IP stack with Socket integration.
So I decided to get the FreeRTOS example with the lwIP stack provided by ST running on my STM32-E407 from Olimex, that contains an STM32F4ZGT6.
After successfully adding the FatFS library I was able to both get Ethernet and SD card working great.
But then I started making my LCD library and got that working, but when I tried my BMP writing routine, which repeatedly fetches 512 bytes (fills a buffer) from a file the application reads and displays two full buffers but then goes into a Hard Fault.
I have tried getting most information out of this Hard Fault exception as possible which can be seen below:
[Hard fault handler - all numbers in hex]
R0 = 20001158
R1 = 1eaf00b4
R2 = 80031a5
R3 = 80031a5
R12 = 20000cac
LR [R14] = a5a5a5a5 subroutine call return address
PC [R15] = fffffffd program counter
PSR = 80078c2
BFAR = 1eaf00b4
CFSR = 8200
HFSR = 40000000
DFSR = 1
AFSR = 0
SCB_SHCSR = 400
I am using the pvPortMalloc(512) to get a pointer to the required 512 bytes buffer, but that didn’t fix the problem.
You can download the CoIDE project (IDE for GCC compiler) and have a look for yourself: http://www.tkjelectronics.dk/uploads/TheBlastFootball_FreeRTOS_HardFault.zip
I really hope that someone can bring me some suggestions.
Best Regards
Thomas Jespersen
