I get a HardFault that is generated from xQsend, looking at the call stack, the top of the stack is vListInsert().
Is it because no space on the queu? I thought that if no space then xQueuSend will just return with an error code.
What could be the reason for the fault?
Thnaks
Just before the crash I can see this comment:
If you find your application is crashing here then likely causes are:
1) Stack overflow -
see http://www.freertos.org/Stacks-and-stack-overflow-checking.html
2) Incorrect interrupt priority assignment, especially on Cortex-M3
parts where numerically high priority values denote low actual
interrupt priories, which can seem counter intuitive. See
configMAX_SYSCALL_INTERRUPT_PRIORITY on http://www.freertos.org/a00110.html
3) Calling an API function from within a critical section or when
the scheduler is suspended, or calling an API function that does
not end in “FromISR” from an interrupt.
4) Using a queue or semaphore before it has been initialised or
before the scheduler has been started (are interrupts firing
before vTaskStartScheduler() has been called?).
See http://www.freertos.org/FAQHelp.html for more tips, and ensure
configASSERT() is defined! http://www.freertos.org/a00110.html#configASSERT
So i tested for stack overflow using method #2 - not a stack overflow, I checked uxCriticalNesting - it is 0 so it is not an API during critical code, and it happens about 250 times after calling the same queue - it is created for sure.
What is left is that it is some interrupt priority problem, which I find not easy to debug, no assertion ishttps://sourceforge.net/p/freertos/discussion/382005/thread/5daa4e7f/# triggered ( configASSERT() is enabled of-course)
Hi, I wonder why I have the last post waiting for
moderation (3 days now). have I done wrong?
thanks
Sorry about that. We just didn’t notice it. No posts should go into moderation, but about once every three months or so for some reason one does, but we don’t get a notification to say this has happened so unfortunately your post just got overlooked.
Whether the assertion would get triggered or not depends on the version of FreeRTOS you are using. Which version are you using?
I moved the code (FatFS on USB host, f_open() ) to a later time in the program execution, so that it will run at a user button press. Just to see what will happen, and it works. I will need some time to investigate this.
Should I find the reason, I will share. I suspect it has to do with the USB host state machine (it has a few states like IDLE, attached, connected etc.).
Thanks
Johanan
