joel_winarske wrote on Wednesday, September 19, 2007:
The GNU version implements:
#define portENTER_SWITCHING_ISR()
#define portEXIT_SWITCHING_ISR( SwitchRequired )
What are the IAR equivalents for these?
Thanks,
Joel
Thanks,
Joel
I have some thick blinders on at the moment, please disregard the above.
Is there a benefit code/speed wise in how the IAR ports are implemented over the GCC?
For example the use of intrinsics.
Has someone done any cycle measurements between the two?
I like the generic implementation of the GCC port, I would just like to be sure I’m not giving myself a performance hit.
Thanks,
Joel
rtel wrote on Wednesday, September 19, 2007:
Are the two not nearly the same? The GCC version is slightly different as interrupt routines are defined completely within C files, and therefore the context is saved/restored in the macro. The IAR inline assembler is not as powerful and requires an asm wrapper to save and restore the context.
I’m tasked to merge the two (GCC/IAR) into a single port. Just looking for insight beyond the obvious.
Joel
