sebamz wrote on Tuesday, November 12, 2013:
I’m having a problem with a global variable I use in my main.c.
I use CAN_FIFO as a buffer to store measured data. When I start the debugger and the program counter is at the beginning of main, there are already values different from zero in CAN_FIFO. The amount of values already written in CAN_FIFO seems to be dependent on how many tasks I create. E.g. if I create only one task, about four values in CAN_FIFO are written and the rest can be used as intended for buffering data. If I create more tasks, there are only a few elements left in which data is stored in the course of the program.
I’m not sure whether my problem is only a compiler issue or about FreeRTOS.
Could someone please give me a few ideas on what could be the cause of this effect?
Please pardon the german comments in my code.
Best regards.
compiler: avrgcc 4.5.1 (AVR Studio 4.19)
debugger: Olimex AVR-JTAG-USB
main.c
/*FreeRTOS V7.5.2 - Copyright © 2013 Real Time Engineers Ltd.
Changes from V4.0.5
+ Modified to demonstrate the use of co-routines.
#include <stdlib.h>
#include <string.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#include <stdint.h>/* EEPROM routines used only with the WinAVR compiler. */
#include <avr/eeprom.h>/* Scheduler include files. */
#include “FreeRTOS.h”
#include “task.h”
//#include “croutine.h”
#include “semphr.h”/* My file headers. */
#include “systemtasks.h”
#include “sensors.h”
#include “init.h”
#include “buffer.h”
#include “datablock.h”
#include “spi_lib.h”
#include “bma020.h”/* Priority definitions for most of the tasks in the application. Some
tasks just use the idle priority. The higher the Value, the higher is the actual priority.*/
#define mainLED_TASK_PRIORITY ( tskIDLE_PRIORITY )
#define mainTIME_TASK_PRIORITY ( tskIDLE_PRIORITY + 2)
#define mainREADC_TASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
#define mainHALL_TASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
#define mainREAD_TEMP_ADC_PRIORITY ( tskIDLE_PRIORITY )
#define mainREAD_SPI_TEMP_PRIORITY ( tskIDLE_PRIORITY )
#define mainREAD_SPI_3DBS_PRIORITY ( tskIDLE_PRIORITY ) //die SPI-Tasks muessen gleiche Prio haben, sonst muss ein Mutex für SPI eingefuert werden!/* Baud rate used by the serial port tasks. */
#define mainCOM_TEST_BAUD_RATE ( ( unsigned long ) 38400 )/* Scheduler TickPeriod in ms*/
#define mainTICK_RATE_MS ( 1000/configTICK_RATE_HZ )/* LED used by the serial port tasks. This is toggled on each character Tx,
and mainCOM_TEST_LED + 1 is toggles on each character Rx. */
#define mainCOM_TEST_LED ( 4 )//Idle Hook Task
//void vApplicationIdleHook( void );//Flashing of LEDs Task
//void vLEDFlashTask( void *pvParameters );//Flashing of LEDs Co-Routine
//void vFlashCoRoutine( xCoRoutineHandle xHandle, unsigned portBASE_TYPE uxIndex );//Read Port C Task
void vReadPortCTask( void *pvParameters );//ADC Sample Battery Voltage Task
void vReadBattVolt(void * pvParameters);//ADC Sample Intake Temperature Task
void vReadIntakeTemp(void * pvParameters);//Incrementing of Systemtime Task
void vRefreshSystemTime( void *pvParameters );//Read Counter 3 counting Result Task
void vReadHallPeriod( void *pvParameters );//Read MAX6675 Temperature over SPI
void vReadSPITemp (void * pvParameters);//Read BMA020 Acceleration
void vRead3DBS (void * pvParameters);/-----------------------------------------------------------/
//Systemzeit
struct time_s SysTime;//Der Datenpuffer für CAN und sein Mutex
struct Buffer CAN_FIFO = {{}, 0, 0};
xSemaphoreHandle xFIFOmutex;//letztes Zaehlergebniss des Timer2 fuer eine Periode des Hall-Signals
volatile uint16_t HallPeriod;/-----------------------------------------------------------/
//tritt auf, wenn Int0 ausgeloest wird
ISR(INT0_vect){
if(TOV3 == 0){ //kein Overflow aufgetreten
//Zwischenspeichern vom Timer3 Zaehlregister (=Zaehlergebnis=>Periodendauer der Radumdrehung)
HallPeriod = TCNT3;
//Reset Timer3 Zaehlregister
else{ //Overflow aufgetreten
HallPeriod = 0xFFFF; //Ergebnis soll Maximalwert sein =>langsamste messbare Raddrehzahl
TIFR3 &= ~(1 << TOV3); //Overflow-Flag loeschen
TCNT3 = 0; //Zaehlergebnis zuruecksetzen
int main( void )
//Test für Debugging
CAN_FIFO.data[0]=11;
CAN_FIFO.data[1]=11;
CAN_FIFO.data[2]=11;
CAN_FIFO.data[3]=31;
CAN_FIFO.data[4]=111;
CAN_FIFO.data[5]=11;
CAN_FIFO.data[10]=12;
CAN_FIFO.data[14]=13;
CAN_FIFO.data[15]=34;
CAN_FIFO.data[20]=99;
//Mutex für CAN_FIFO erstellen, damit nicht mehrere Tasks gleichzeitig auf CAN_FIFO zugreifen können
xFIFOmutex = xSemaphoreCreateMutex();<span style="color: #408080; font-style: italic">//Initialisierungen</span> vIO_Init(); vInitExtInt0(); vInitTimer3(); <span style="color: #408080; font-style: italic">//Reihenfolge wichtig!</span> vInitSPI_SS (); spi_init((<span style="color: #B00040">uint8_t</span>)(SPI_MASTER<span style="color: #666666">|</span>SPI_MSB_FIRST<span style="color: #666666">|</span>SPI_DATA_MODE_0<span style="color: #666666">|</span>SPI_CLKIO_BY_16)); vInit3DBS(); <span style="color: #408080; font-style: italic">//Reihenfolge wichtig!</span> <span style="color: #408080; font-style: italic">//Create Tasks</span> <span style="color: #408080; font-style: italic">// xTaskCreate (task function name, task name (choose freely), stack size, pointer to task parameters, task priority, pass back handle by reference)</span> <span style="color: #408080; font-style: italic">//xTaskCreate( vLEDFlashTask, ( signed char * ) "LED", configMINIMAL_STACK_SIZE, NULL, mainLED_TASK_PRIORITY, NULL );</span> xTaskCreate ( vRefreshSystemTime, ( <span style="color: #B00040">signed</span> <span style="color: #B00040">char</span> <span style="color: #666666">*</span> ) <span style="color: #BA2121">"SYSTIME"</span>, configMINIMAL_STACK_SIZE, ( <span style="color: #B00040">void</span> <span style="color: #666666">*</span> ) <span style="color: #666666">&</span>SysTime, mainTIME_TASK_PRIORITY, <span style="color: #008000">NULL</span>); xTaskCreate ( vReadPortCTask, ( <span style="color: #B00040">signed</span> <span style="color: #B00040">char</span> <span style="color: #666666">*</span> ) <span style="color: #BA2121">"READC"</span>, configMINIMAL_STACK_SIZE, <span style="color: #008000">NULL</span>, mainREADC_TASK_PRIORITY, <span style="color: #008000">NULL</span>); <span style="color: #408080; font-style: italic">//xTaskCreate ( vReadBattVolt, ( signed char * ) "ADCBATT", configMINIMAL_STACK_SIZE, NULL, mainREAD_TEMP_ADC_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//xTaskCreate ( vReadIntakeTemp, ( signed char * ) "INTEMP", configMINIMAL_STACK_SIZE, NULL, mainREAD_TEMP_ADC_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//xTaskCreate ( vReadHallPeriod, ( signed char * ) "HALL", configMINIMAL_STACK_SIZE, NULL, mainHALL_TASK_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//xTaskCreate ( vReadSPITemp, ( signed char * ) "ET1", configMINIMAL_STACK_SIZE, ( void * ) SS0, mainREAD_SPI_TEMP_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//xTaskCreate ( vReadSPITemp, ( signed char * ) "ET2", configMINIMAL_STACK_SIZE, ( void * ) SS1, mainREAD_SPI_TEMP_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//xTaskCreate ( vReadSPITemp, ( signed char * ) "ET3", configMINIMAL_STACK_SIZE, ( void * ) SS2, mainREAD_SPI_TEMP_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//xTaskCreate ( vReadSPITemp, ( signed char * ) "ET4", configMINIMAL_STACK_SIZE, ( void * ) SS3, mainREAD_SPI_TEMP_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//xTaskCreate ( vRead3DBS, ( signed char * ) "3DBS", configMINIMAL_STACK_SIZE, NULL, mainREAD_SPI_3DBS_PRIORITY, NULL);</span> <span style="color: #408080; font-style: italic">//Create Co-Routines</span> <span style="color: #408080; font-style: italic">//xCoRoutineCreate (co-routine name, co-routine priority, index)</span> <span style="color: #408080; font-style: italic">//xCoRoutineCreate( vFlashCoRoutine, 0, 0 );</span> HallPeriod <span style="color: #666666">=</span> <span style="color: #666666">0xFFFF</span>; <span style="color: #408080; font-style: italic">//Maximalwert =>langsamste messbare Raddrehzahl</span> sei(); vTaskStartScheduler(); <span style="color: #008000; font-weight: bold">while</span> (<span style="color: #666666">1</span>){}; <span style="color: #008000; font-weight: bold">return</span> <span style="color: #666666">0</span>;}//int main( void )
//Implementation of tasks
