olafp wrote on March 26, 2018:
Hi Gaurav,
Thanks for your reply!
Ok, I have ordered MIKROE-1203 (USB UART Click Board).
I tried to debug the project you referred to in http://www.microchip.com/mymicrochip/filehandler.aspx?ddocname=en588540
I found and opened the project “cdc_com_port_dual” from the Harmony framework.
Made 2 modifications from “Project Properties”
- SettingDevice to Pic32MZ2048EFM100
- Debug Tool to Starter Kits(PKOB)
I then tried to debug the demo project, but build failed.
Since its a demo project, I assume my build system is setup incorrect. It seem like this curiosity board does not have some HW feature that is needed.
But I have encountered “Project Loading Error” when loading the “aws_demos” project in MPLAB X IDE. That indicate that MPLAB X is not configured correctly.
So my questions/wishes to the Microchip Curiosity PIC32MZEF demo are:
- More detailed instruction setting up MPLAB X build environment.
- More detailed info how to use the local MPLAB X debugger, and AWS IoT -Test environment.
Appreciate any feedback, thanks.
Olaf
Build log for cdc_com_port_dual:
"make -f nbproject/Makefile-pic32mk_gp_db_int_dyn.mk SUBPROJECTS= .build-conf
make[1]: Entering directory ‘C:/microchip/harmony/v2_05_01/apps/usb/multi_usb/cdc_com_port_dual/firmware/cdc_com_port_dual.X’
make -f nbproject/Makefile-pic32mk_gp_db_int_dyn.mk dist/pic32mk_gp_db_int_dyn/debug/cdc_com_port_dual.X.debug.elf
make[2]: Entering directory ‘C:/microchip/harmony/v2_05_01/apps/usb/multi_usb/cdc_com_port_dual/firmware/cdc_com_port_dual.X’
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c: In function ‘SYS_CLK_Initialize’:
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:97:2: error: ‘PLIB_OSC_UPLLInputDivisorSet’ is unsupported: The microcontroller selected does not implement this feature. [-Werror]
PLIB_OSC_UPLLInputDivisorSet(OSC_ID_0, OSC_UPLL_IN_DIV_1);
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:97:41: error: ‘OSC_UPLL_IN_DIV_1’ undeclared (first use in this function)
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:97:41: note: each undeclared identifier is reported only once for each function it appears in
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:98:2: error: ‘PLIB_OSC_UPLLFrequencyRangeSet’ is unsupported: The microcontroller selected does not implement this feature. [-Werror]
PLIB_OSC_UPLLFrequencyRangeSet(OSC_ID_0, OSC_UPLL_FREQ_RANGE_8M_TO_16M);
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:98:43: error: ‘OSC_UPLL_FREQ_RANGE_8M_TO_16M’ undeclared (first use in this function)
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:99:2: error: ‘PLIB_OSC_UPLLMultiplierSelect’ is unsupported: The microcontroller selected does not implement this feature. [-Werror]
PLIB_OSC_UPLLMultiplierSelect(OSC_ID_0, 32);
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:100:2: error: ‘PLIB_OSC_UPLLOutputDivisorSet’ is unsupported: The microcontroller selected does not implement this feature. [-Werror]
PLIB_OSC_UPLLOutputDivisorSet(OSC_ID_0, OSC_UPLL_OUT_DIV_8);
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:100:42: error: ‘OSC_UPLL_OUT_DIV_8’ undeclared (first use in this function)
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:102:2: error: ‘PLIB_OSC_UsbClockSourceSelect’ is unsupported: The microcontroller selected does not implement this feature. [-Werror]
PLIB_OSC_UsbClockSourceSelect (OSC_ID_0, SYS_OSC_USBCLK_PRIMARY);
…/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c:102:43: error: ‘SYS_OSC_USBCLK_PRIMARY’ undeclared (first use in this function)
cc1.exe: all warnings being treated as errors
make[2]: *** [build/pic32mk_gp_db_int_dyn/debug/_ext/784443848/sys_clk_pic32mk.o] Error 1
make[2]: *** Waiting for unfinished jobs…
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/784443848/sys_clk_pic32mk.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/784443848/sys_clk_pic32mk.o …/src/system_config/pic32mk_gp_db_int_dyn/framework/system/clk/src/sys_clk_pic32mk.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
nbproject/Makefile-pic32mk_gp_db_int_dyn.mk:116: recipe for target ‘build/pic32mk_gp_db_int_dyn/debug/_ext/784443848/sys_clk_pic32mk.o’ failed
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/548107327/bsp.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/548107327/bsp.o …/src/system_config/pic32mk_gp_db_int_dyn/bsp/bsp.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
…/src/system_config/pic32mk_gp_db_int_dyn/system_interrupt.c:74:1: error: Vector number must be an integer between 0 and 255
…/src/system_config/pic32mk_gp_db_int_dyn/system_interrupt.c:79:1: error: Vector number must be an integer between 0 and 255
make[2]: *** [build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_interrupt.o] Error 1
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_interrupt.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_interrupt.o …/src/system_config/pic32mk_gp_db_int_dyn/system_interrupt.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
nbproject/Makefile-pic32mk_gp_db_int_dyn.mk:146: recipe for target ‘build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_interrupt.o’ failed
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/797334065/sys_devcon_pic32mk.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/797334065/sys_devcon_pic32mk.o …/src/system_config/pic32mk_gp_db_int_dyn/framework/system/devcon/src/sys_devcon_pic32mk.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/1360937237/app.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/1360937237/app.o …/src/app.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/797334065/sys_devcon.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/797334065/sys_devcon.o …/src/system_config/pic32mk_gp_db_int_dyn/framework/system/devcon/src/sys_devcon.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/738678904/sys_ports_static.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/738678904/sys_ports_static.o …/src/system_config/pic32mk_gp_db_int_dyn/framework/system/ports/src/sys_ports_static.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/1360937237/main.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/1360937237/main.o …/src/main.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_exceptions.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_exceptions.o …/src/system_config/pic32mk_gp_db_int_dyn/system_exceptions.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_tasks.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_tasks.o …/src/system_config/pic32mk_gp_db_int_dyn/system_tasks.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:100:9: error: unknown configuration setting: ‘VBATBOREN’
#pragma config VBATBOREN = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:101:9: error: unknown configuration setting: ‘DSBOREN’
#pragma config DSBOREN = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:102:9: error: unknown configuration setting: ‘DSWDTPS’
#pragma config DSWDTPS = DSPS32
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:103:9: error: unknown configuration setting: ‘DSWDTOSC’
#pragma config DSWDTOSC = LPRC
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:104:9: error: unknown configuration setting: ‘DSWDTEN’
#pragma config DSWDTEN = OFF
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:105:9: error: unknown configuration setting: ‘FDSEN’
#pragma config FDSEN = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:106:9: error: unknown configuration setting: ‘BORSEL’
#pragma config BORSEL = HIGH
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:107:9: error: unknown configuration setting: ‘UPLLEN’
#pragma config UPLLEN = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:111:9: error: unknown configuration setting: ‘FUSBIDIO2’
#pragma config FUSBIDIO2 = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:112:9: error: unknown configuration setting: ‘FVBUSIO2’
#pragma config FVBUSIO2 = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:116:9: error: unknown configuration setting: ‘FUSBIDIO1’
#pragma config FUSBIDIO1 = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:117:9: error: unknown configuration setting: ‘FVBUSIO1’
#pragma config FVBUSIO1 = ON
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:161:14: error: ‘USB_ID_1’ undeclared here (not in a function)
.usbID = USB_ID_1
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:170:24: error: ‘INT_SOURCE_USB_2’ undeclared here (not in a function)
.interruptSource = INT_SOURCE_USB_2,
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:186:14: error: ‘USB_ID_2’ undeclared here (not in a function)
.usbID = USB_ID_2
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c: In function ‘SYS_Initialize’:
In file included from …/…/…/…/…/…/framework/system/int/sys_int.h:964:0,
from …/src/system_config/pic32mk_gp_db_int_dyn/system_definitions.h:54,
from …/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:50:
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:791:31: error: ‘INT_VECTOR_USB2’ undeclared (first use in this function)
SYS_INT_VectorPrioritySet(INT_VECTOR_USB2, INT_PRIORITY_LEVEL4);
…/…/…/…/…/…/framework/system/int/sys_int_mapping.h:207:46: note: in definition of macro ‘SYS_INT_VectorPrioritySet’
PLIB_INT_VectorPrioritySet( INT_ID_0,vector, priority)
…/src/system_config/pic32mk_gp_db_int_dyn/system_init.c:791:31: note: each undeclared identifier is reported only once for each function it appears in
make[2]: *** [build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_init.o] Error 1
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
“C:\Program Files (x86)\Microchip\xc32\v2.05\bin\xc32-gcc.exe” -g -D__DEBUG -DPKOBSKDEPlatformTool=1 -fframe-base-loclist -x c -c -mprocessor=32MZ2048EFM100 -ffunction-sections -O1 -I…/src -I…/src/system_config/pic32mk_gp_db_int_dyn -I…/src/pic32mk_gp_db_int_dyn -I…/…/…/…/…/…/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/framework -I…/src/system_config/pic32mk_gp_db_int_dyn/bsp -Werror -Wall -MMD -MF build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_init.o.d -o build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_init.o …/src/system_config/pic32mk_gp_db_int_dyn/system_init.c -DXPRJ_pic32mk_gp_db_int_dyn=pic32mk_gp_db_int_dyn -no-legacy-libc
nbproject/Makefile-pic32mk_gp_db_int_dyn.mk:140: recipe for target ‘build/pic32mk_gp_db_int_dyn/debug/_ext/518178801/system_init.o’ failed
make[2]: Leaving directory ‘C:/microchip/harmony/v2_05_01/apps/usb/multi_usb/cdc_com_port_dual/firmware/cdc_com_port_dual.X’
nbproject/Makefile-pic32mk_gp_db_int_dyn.mk:90: recipe for target ‘.build-conf’ failed
make[1]: Leaving directory ‘C:/microchip/harmony/v2_05_01/apps/usb/multi_usb/cdc_com_port_dual/firmware/cdc_com_port_dual.X’
nbproject/Makefile-impl.mk:39: recipe for target ‘.build-impl’ failed
BUILD FAILED (exit value 2, total time: 10s)"
“aws_demos” project loading errors log:
Error: Project “harmony_boot” refers to file “bootloader.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “nvm.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “datastream.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_tmr_variant_mapping.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_tmr_local.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_tmr.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_tmr_mapping.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_tmr_compatibility.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “tmr_definitions_pic32m.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_usart_variant_mapping.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_usart_local.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_usart.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “drv_usart_definitions.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “driver.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “driver_common.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “osal.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “osal_definitions.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “osal_impl_basic.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_clk.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_clk_compatibility.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_clk_mapping.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_command.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_common.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_module.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_buffer.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_queue.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_console_local.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_console_uart.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_console.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_debug_local.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_debug.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_dma.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_dma_definitions.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_fs.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_int_private.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_int.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_int_mapping.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_ports.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_ports_definitions.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_reset.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_reset_definitions_pic32m.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_tmr_local.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “sys_tmr.h” which does not exist in the disk. The project failed to load.
Error: Project “harmony_boot” refers to file “system.h” which does not exist in the disk. The project failed to load.
