I do have configENABLE_BACKWARD_COMPATIBILITY set to 1. However is it defined as 1 in FreeRTOS.h. This is my FreeRTOSConfig.h file:
* FreeRTOS V202107.00
* Copyright (C) 2020 Amazon.com, Inc. or its affiliates. All Rights Reserved.
* Permission is hereby granted, free of charge, to any person obtaining a copy of
* this software and associated documentation files (the "Software"), to deal in
* the Software without restriction, including without limitation the rights to
* use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies of
* the Software, and to permit persons to whom the Software is furnished to do so,
* subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all
* copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
* https://www.FreeRTOS.org
* https://github.com/FreeRTOS
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
* Application specific definitions.
* These definitions should be adjusted for your particular hardware and
* application requirements.
* THESE PARAMETERS ARE DESCRIBED WITHIN THE 'CONFIGURATION' SECTION OF THE
* FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
* See https://www.freertos.org/a00110.html
#define configASSERT_DEFINED 1
extern void vAssertCalled( void );
#define configASSERT( x ) if( ( x ) == 0 ) vAssertCalled()
#define configQUEUE_REGISTRY_SIZE 20
#define configUSE_TIME_SLICING 1
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 1
#define configUSE_IDLE_HOOK 1
#define configUSE_TICK_HOOK 1
#define configUSE_DAEMON_TASK_STARTUP_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned long ) 24000000 )
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 ) //1000 Hz OS tick
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 250 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 10000 ) )
#define configMAX_TASK_NAME_LEN ( 16 )
#define configUSE_TRACE_FACILITY 0
#define configMAX_PRIORITIES ( 10 )
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define configTIMER_QUEUE_LENGTH 20
#define configTIMER_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
#define configUSE_COUNTING_SEMAPHORES 1
#define configSUPPORT_DYNAMIC_ALLOCATION 1
#define configSUPPORT_STATIC_ALLOCATION 0
#define configNUM_TX_DESCRIPTORS 15
#define configSTREAM_BUFFER_TRIGGER_LEVEL_TEST_MARGIN 2
* to exclude the API function. */
#define configUSE_MALLOC_FAILED_HOOK 1
#define configUSE_MUTEXES 1
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_TIMERS 1
#define configTIMER_TASK_STACK_DEPTH ( configMINIMAL_STACK_SIZE * 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#define INCLUDE_uxTaskGetStackHighWaterMark2 1
#define INCLUDE_xTaskGetSchedulerState 1
#define INCLUDE_xTimerGetTimerDaemonTaskHandle 1
#define INCLUDE_xTaskGetIdleTaskHandle 1
#define INCLUDE_xTaskGetHandle 1
#define INCLUDE_eTaskGetState 1
#define INCLUDE_xSemaphoreGetMutexHolder 1
#define INCLUDE_xTimerPendFunctionCall 1
#define INCLUDE_xTaskAbortDelay 1
unsigned long ulGetRunTimeCounterValue( void ); /* Prototype of function that returns run time counter. */
#define projCOVERAGE_TEST 0
#define configKERNEL_INTERRUPT_PRIORITY 255
* See http://www.FreeRTOS.org/RTOS-Cortex-M3-M4.html. */
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 191 /* equivalent to 0xa0, or priority 5. */
#define configMAC_INTERRUPT_PRIORITY 5
/* Prototype for the function used to print out. In this case it prints to the
| 10 console before the network is connected then a UDP port after the network has
| 9 connected. */
extern void vLoggingPrintf( const char * pcFormatString,
#ifdef HEAP3
#define xPortGetMinimumEverFreeHeapSize ( x )
#define xPortGetFreeHeapSize ( x )
I’m not 100% on all the settings, so if you see something wrong please point it out to me.
Also I was able to solve the multiple definitions issue. Port.c defined xPortSysTickHandler, xPortPendSVHandler, and vPortSVCHandler, but the prototypes for the functions weren’t in portable.h, which is what FreeRTOS.h includes, not port.c. In my CM3Start.h file, where the interrupt vector is, I originally included port.c but then it didn’t see the prototype of the pxPortInitialiseStack function because of the include order. So I added the prototypes for the interupt functions in to portable.h and included FreeRTOS.h in the CM3Start.h file. This solved the issue where it said the interrupt functions were undefined, and the issue where there were multiple definitions of pxPortInitialiseStack. So that’s all good (I think).
However, now I’m back to square 1
. It’s doing the same thing in the first post, where it ends up in CY_ISR(IntDefaultHandler) after executing the prvPortStartFirstTask function. I would expect the interrupts to be set correctly since I added those functions in the vector table. I think I need to do something else to get the interrupts set properly. I’m not sure what.
Also this is my make file. I did copy files over from the demo application to a separate project after making. Maybe I missed something? I’m not completely sure what the make file is doing to set the interrupts, so that could be what I missed.
CC = arm-none-eabi-gcc
BIN := RTOSDemo.axf
BUILD_DIR := build
FREERTOS_DIR_REL := ../../../FreeRTOS
FREERTOS_DIR := $(abspath $(FREERTOS_DIR_REL))
KERNEL_DIR := $(FREERTOS_DIR)/Source
FREERTOS_PLUS_DIR_REL := ../../../FreeRTOS-Plus
FREERTOS_PLUS_DIR := $(abspath $(FREERTOS_PLUS_DIR_REL))
SOURCE_FILES += init/startup.c syscall.c main.c
SOURCE_FILES += $(KERNEL_DIR)/portable/GCC/ARM_CM3/port.c
SOURCE_FILES += $(KERNEL_DIR)/tasks.c
SOURCE_FILES += $(KERNEL_DIR)/list.c
SOURCE_FILES += $(KERNEL_DIR)/queue.c
SOURCE_FILES += $(KERNEL_DIR)/timers.c
SOURCE_FILES += $(KERNEL_DIR)/event_groups.c
SOURCE_FILES += ${KERNEL_DIR}/portable/MemMang/heap_3.c
INCLUDE_DIRS += -I$(FREERTOS_DIR)/Demo/CORTEX_M3_MPS2_QEMU_GCC
INCLUDE_DIRS += -I$(FREERTOS_DIR)/Demo/CORTEX_M3_MPS2_QEMU_GCC/CMSIS
INCLUDE_DIRS += -I$(KERNEL_DIR)/include
INCLUDE_DIRS += -I$(KERNEL_DIR)/portable/GCC/ARM_CM3
ifeq ($(FULL_DEMO), 1)
SOURCE_FILES += main_full.c
SOURCE_FILES += $(KERNEL_DIR)/stream_buffer.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/AbortDelay.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/BlockQ.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/blocktim.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/countsem.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/death.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/dynamic.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/EventGroupsDemo.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/flop.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/GenQTest.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/integer.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/IntSemTest.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/MessageBufferAMP.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/MessageBufferDemo.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/PollQ.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/QPeek.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/QueueOverwrite.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/QueueSet.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/QueueSetPolling.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/recmutex.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/semtest.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/StaticAllocation.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/StreamBufferDemo.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/StreamBufferInterrupt.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/TaskNotify.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Minimal/TimerDemo.c
SOURCE_FILES += ${FREERTOS_DIR}/Demo/Common/Full/print.c
INCLUDE_DIRS += -I$(FREERTOS_DIR)/Demo/Common/include
INCLUDE_DIRS += -I${FREERTOS_PLUS_DIR}/Source/FreeRTOS-Plus-Trace/Include/
CFLAGS := -DmainCREATE_FULL_DEMO_ONLY=1
SOURCE_FILES += main_blinky.c
CFLAGS := -DmainCREATE_SIMPLE_BLINKY_DEMO_ONLY=1
endif
DEFINES := -DQEMU_SOC_MPS2 -DHEAP3
LDFLAGS = -T ./scripts/mps2_m3.ld -specs=nano.specs --specs=rdimon.specs -lc -lrdimon
LDFLAGS += -Xlinker -Map=${BUILD_DIR}/output.map
CFLAGS += -nostartfiles -mthumb -mcpu=cortex-m3 -Wno-error=implicit-function-declaration
CFLAGS += -Wno-builtin-declaration-mismatch -Werror
ifeq ($(DEBUG), 1)
CFLAGS += -ggdb3 -Og
CFLAGS += -O3
endif
CFLAGS += -fstrict-aliasing -Wstrict-aliasing -Wno-error=address-of-packed-member
OBJ_FILES := $(SOURCE_FILES:%.c=$(BUILD_DIR)/%.o)
CPPFLAGS += $(DEFINES)
CFLAGS += $(INCLUDE_DIRS)
.PHONY: clean
$(BUILD_DIR)/$(BIN) : $(OBJ_FILES)
$(CC) -ffunction-sections -fdata-sections $(CFLAGS) $(LDFLAGS) $+ -o $(@)
%.d: %.c
@set -e; rm -f $@; \
$(CC) -M $(CPPFLAGS) $< > $@.$$$$; \
sed 's,\($*\)\.o[ :]*,\1.o $@ : ,g' < $@.$$$$ > $@; \
rm -f $@.$$$$
INCLUDES := $(SOURCE_FILES:%.c=$(BUILD_DIR)/%.d)
-include $(INCLUDES)
${BUILD_DIR}/%.o : %.c Makefile
-mkdir -p $(@D)
$(CC) $(CFLAGS) $(CPPFLAGS) -MMD -c $< -o $@
clean:
-rm -rf build
Thank you!
Edit: forgot to add makefile.
