system
(system)
1
andrewalo wrote on Tuesday, January 13, 2015:
Hi Guys,
Sorry for my first newbie knowledge of freertos. I’m tryng to generate an interrupt to call an handler function.
On the practical guide i’ve read this statements:
_asm{} //to generate interrupt
static void _interrupt _ far handlerfunc(void) {} //to define handler func
_dos_setvect{} //to install the handler func
but i think that they’re for another architecture,
is there a guide for make this on MSVC?maybe an example.
Thank you
rtel
(Richard Barry)
2
rtel wrote on Tuesday, January 13, 2015:
As the simulator is running under Windows, and not actually simulating any hardware, it is not possible to generate real interrupts. However you can generate simulated interrupts. See the following link:
http://www.freertos.org/FreeRTOS-Windows-Simulator-Emulator-for-Visual-Studio-and-Eclipse-MingW.html#SimulatedISRs
system
(system)
3
Yeah!i was written how i resolved, if someone needs help:
vPortGenerateSimulatedInterrupt( portINTERRUPT_YIELD2 );//generate interrupt
static uint32_t handlerfunc(void){}//interrupt handler (NOT UNSIGNED LONG)
vPortSetInterruptHandler( portINTERRUPT_YIELD2, handlerfunc );//install interrupt
and in the portmacro.h, #define portINTERRUPT_YIELD2 (2UL)/or another value/
Thank you
