Hi all
FreeRTOS: 7.2.0
MCU: TM4C1231
Memory alloc: heap_4
My application works when compiled with GCC 4.7. I’ve updated to GCC 4.8 and the same application is unstable, and reports unreasonably large numbers from xPortGetFreeHeapSize, e.g.:
GCC 4.7.1 7800 bytes
GCC 4.8.3 33537864 bytes
I’ve tried updating to FreeRTOS 8.2.3 but this makes no difference. I have a task StackOverflowHook installed but it is not being called.
I would appreciate any suggestions/ideas. Unfortunately the JTAG port on my hardware isn’t easily accessible for debugging.
Thanks
Is there a higher gcc version available ( >= 4.9.1 ? ) for the TM4C1231 ?
In 4.8, for the first time, the gcc compiler is compiled by a C++ compiler.
It is not unthinkable that some regression has taken place.
Did you try different levels of optimisation already? -O0, -O1, -O2 and (my favourite) -Os ?
It is a pity that embedded debugging is difficult. If not I would definitely check the value of ‘xFreeBytesRemaining’, see why and when it becomes extremely high.
Do you have a listing ( main.lss mixed with C-code ) of the functions in heap_4.c ?
Thanks for your suggestions. I’m still investigating, but I think that my problem is a bug in our linker script, and changing the compiler has made the problem show up. So it’s not a FreeRTOS fault.
