FTP RETR command truncates files on RAM disk.
I managed to reproduce the same problem with CLI.
It happens if I add “//” before file name as FTP server does.
Beside this FTP hangs on get, dir.
Please see log below:
–>dir
test.txt [writable file] [size=2048] <<< File is OK
. [directory] [size=1024]
–>type test.txt
Hello word
–>type //test.txt
–>dir
test.txt [writable file] [size=0] <<** file is truncated**
target log:
–>type log.txt
test log
TCP socket on port 80
TCP socket on port
21
TPC-server: new FTP client
USER
PORT a041418ip:56940
Client address a041418ip:5694
0
RETR test.txt
FTP: sent: ‘//test.txt’ 0 B
ytes (0 bytes/sec)
I can try and replicate the behaviour here. Can you please provide more
information on how to duplicate it. I understand you are sending a file
that has // on the front, but how are you sending it? For example, is
this done from a command line or from an IDE. If it is done from a
command line please show the commands you are using.
So this is not an FTP issue - from your first post I thought it was.
Simply trying to view a file after adding // to the front of the file
name. I will give that a try, although // is not a valid path to the
file it should not result in the file being truncated.
Actually I have an issues with FTP as well - it hangs on DIR, RETR command.
after DIR command it enters tight loop and I had to enter some delay in order to get some responce
for( ;; )
FreeRTOS_TCPServerWork( pxTCPServer, xInitialBlockTime );
vTaskDelay(10); <<-- added delay
Truncated file is something solid that managed to see and reproduce.
I just tried what I think you tried before, albeit with the head revision code rather than the release code. The output is below:
First, view a small file I FTPed onto the RAM disk, which is mounted in /
[Press ENTER to execute the previous command again]
dir
p.txt [writable file] [size=38]
Then I view the file without the // on the front.
type p.txt
11111111111111111111111111111111111111
Performing a directory listing shows the file has the same length:
dir
Then I do the same, but this time add the // to the front of the file name:
type //p.txt
When I perform a directory listing again the file has not been truncated.
dir
I’m using the head revision, which is not in a public repository, if you
send me your files (not your own code, just the FreeRTOS, FreeRTOS+FAT
and FreeRTOS+TCP files) then I can update those files to the latest
version and send them back. You can contact me on r dot barry at
freertos [dot] org.
I have updated the +TCP and +FAT code to the head revision of the single interface TCP version - pay no attention to the version number in the header files as its not release code just a working copy. It looks like you were actually using quite an old version. I have not updated any of the other files - you may also like to use FreeRTOS V9.0.0, which you can download from SourceForge here.
–>type //test.txt
–>dir
Isn’t //test.txt an invalid file name?
+FAT does have code to handle relative paths, it also recognises invalid characters, but it doesn’t always detect invalid paths or file names.
I think it is even possible to create a file with an empty string as a file name.
For some people, this is a short-coming. For others it is a blessing because they want a fast and small library.
We could add some more code checking path validity and make this dependent on some macro ffconfigCHECK_PATH_VALIDITY
I tested a new version, result is the same.
I think that something is wrong with ramdisk/filesystem configuration. DIR reports 2048 bytes, while in your example I see 28 bytes.
Can you send me you setup of RAMDISK?
–>dir test.txt [writable file] [size=2048]
log.txt [writable file] [size=2048]
–>type test.txt
Hello word
–>type //test.txt
Do you have ffconfigPATH_CACHE enabled? It remembers the cluster number that belongs to a certain path.
You could try the same test with:
#define ffconfigPATH_CACHE 0
But once again, //test.txt is an invalid file name and I think that any API called with such an entry should return an error.
( at this moment I don’t have any hardware with a RAM-disk. Beginning of August I will replicate the problem and come back to it )
ffconfigPATH_CACHE is not defined by default.
I know that // is not valid, maybe it is symphom for other problem as well as reporting of wrong size of file.
BTW. Truncation does not happen and size is reported correctly if file is in sub-folder
