qwlimited wrote on Thursday, August 10, 2017:
Hello ,
I am new to FreeRTOS and +TCP, I create a simple echo server, almost every time when I connect/disconnect from echo server, there are 616 bytes gone.
echo heap: 26328
echo heap: 25712
echo heap: 25712
echo heap: 25712
echo heap: 25712
echo heap: 25096
echo heap: 25096
echo heap: 25096
echo heap: 25096
echo heap: 24480
My code as following, many thanks for your kind help
Kevin
void vTcpEchoTask(void *arg)
struct freertos_sockaddr xClient, xBindAddress;
Socket_t xListeningSocket, xConnectedSocket;
socklen_t xSize = sizeof( xClient );
static const TickType_t xReceiveTimeOut = portMAX_DELAY;
const BaseType_t xBacklog = 1;
static char cRxedData[ 128 ];
BaseType_t lBytesReceived;
/* Attempt to open the socket. */
xListeningSocket = FreeRTOS_socket( FREERTOS_AF_INET,
FREERTOS_SOCK_STREAM, /* SOCK_STREAM for TCP. */
FREERTOS_IPPROTO_TCP );
/* Check the socket was created. */
configASSERT( xListeningSocket != FREERTOS_INVALID_SOCKET );
/* If FREERTOS_SO_RCVBUF or FREERTOS_SO_SNDBUF are to be used with
FreeRTOS_setsockopt() to change the buffer sizes from their default then do
it here!. (see the FreeRTOS_setsockopt() documentation. */
/* If ipconfigUSE_TCP_WIN is set to 1 and FREERTOS_SO_WIN_PROPERTIES is to
be used with FreeRTOS_setsockopt() to change the sliding window size from
its default then do it here! (see the FreeRTOS_setsockopt()
documentation. */
/* Set a time out so accept() will just wait for a connection. */
FreeRTOS_setsockopt( xListeningSocket,
0,
FREERTOS_SO_RCVTIMEO,
&xReceiveTimeOut,
sizeof( xReceiveTimeOut ) );
/* Set the listening port to 7. */
xBindAddress.sin_port = ( uint16_t ) 7;
xBindAddress.sin_port = FreeRTOS_htons( xBindAddress.sin_port );
/* Bind the socket to the port that the client RTOS task will send to. */
FreeRTOS_bind( xListeningSocket, &xBindAddress, sizeof( xBindAddress ) );
/* Set the socket into a listening state so it can accept connections.
The maximum number of simultaneous connections is limited to 20. */
FreeRTOS_listen( xListeningSocket, xBacklog );
for( ;; )
/* Wait for incoming connections. */
xConnectedSocket = FreeRTOS_accept( xListeningSocket, &xClient, &xSize );
configASSERT( xConnectedSocket != FREERTOS_INVALID_SOCKET );
printf(“echo heap: %d \n”, xPortGetFreeHeapSize() );
for(;
/* Receive another block of data into the cRxedData buffer. */
lBytesReceived = FreeRTOS_recv( xConnectedSocket, &cRxedData, 128, 0 );
if( lBytesReceived > 0 )
/* Data was received, process it here. */
//prvPorcessData( cRxedData, lBytesReceived );
FreeRTOS_send( /* The socket being sent to. */
xConnectedSocket,
/* The data being sent. */
&( cRxedData[ 0 ] ),
/* The remaining length of data to send. */
lBytesReceived,
/*ulFlags. */
0 );
else if( lBytesReceived == 0 )
/* No data was received, but FreeRTOS_recv() did not return an error.
Timeout? */
/* Error (maybe the connected socket already shut down the socket?).
Attempt graceful shutdown. */
FreeRTOS_shutdown( xConnectedSocket, FREERTOS_SHUT_RDWR );
break;
} //tcp_receive loop
/* The RTOS task will get here if an error is received on a read. Ensure the
socket has shut down (indicated by FreeRTOS_recv() returning a FREERTOS_EINVAL
error before closing the socket). */
while( FreeRTOS_recv( xConnectedSocket, cRxedData, lBytesReceived, 0 ) >= 0 )
/* Wait for shutdown to complete. If a receive block time is used then
this delay will not be necessary as FreeRTOS_recv() will place the RTOS task
into the Blocked state anyway. */
osDelay(250 );
/* Note - real applications should implement a timeout here, not just
loop forever. */
/* Shutdown is complete and the socket can be safely closed. */
FreeRTOS_closesocket( xConnectedSocket );
/* Must not drop off the end of the RTOS task - delete the RTOS task. */
osThreadTerminate(NULL);
