voloviq wrote on Friday, February 10, 2012:
I ported example number 2 for pic18f452 to pic18f25k80. Porting sucesful everything compile etc.
When I create one task just only one task which receive some data from queue UART1 system restar in some period (period is different all the times).
Below my configuration:
Linker script:
// File: 18f25k80_g.lkr
// Generic linker script for the PIC18F25K80 processor
#DEFINE _CODEEND _DEBUGCODESTART - 1
#DEFINE _CEND _CODEEND + _DEBUGCODELEN
#DEFINE _DATAEND _DEBUGDATASTART - 1
#DEFINE _DEND _DATAEND + _DEBUGDATALEN
LIBPATH .
#IFDEF _CRUNTIME
#IFDEF _EXTENDEDMODE
FILES c018i_e.o
FILES clib_e.lib
FILES p18F25K80_e.lib
#ELSE
FILES c018i.o
FILES clib.lib
FILES p18F25K80.lib
#FI
#FI
#IFDEF _DEBUGCODESTART
CODEPAGE NAME=page START=0x0 END=_CODEEND
CODEPAGE NAME=debug START=_DEBUGCODESTART END=_CEND PROTECTED
#ELSE
CODEPAGE NAME=page START=0x0 END=0x7FFF
#FI
CODEPAGE NAME=userid START=0x200000 END=0x200007 PROTECTED
CODEPAGE NAME=cfgmem START=0x300000 END=0x30000D PROTECTED
CODEPAGE NAME=devid START=0x3FFFFE END=0x3FFFFF PROTECTED
CODEPAGE NAME=eedata START=0xF00000 END=0xF003FF PROTECTED
DATABANK NAME=gpre START=0x0 END=0x5F
#ELSE
ACCESSBANK NAME=accessram START=0x0 END=0x5F
#FI
//DATABANK NAME=gpr0 START=0x60 END=0xFF
//DATABANK NAME=gpr1 START=0x100 END=0x1FF
//DATABANK NAME=gpr2 START=0x200 END=0x2FF
//DATABANK NAME=gpr3 START=0x300 END=0x3FF
//DATABANK NAME=gpr4 START=0x400 END=0x4FF
//DATABANK NAME=gpr5 START=0x500 END=0x5FF
//DATABANK NAME=gpr6 START=0x600 END=0x6FF
//DATABANK NAME=gpr7 START=0x700 END=0x7FF
//DATABANK NAME=gpr8 START=0x800 END=0x8FF
//DATABANK NAME=gpr9 START=0x900 END=0x9FF
//DATABANK NAME=gpr10 START=0xA00 END=0xAFF
//DATABANK NAME=gpr11 START=0xB00 END=0xBFF
//DATABANK NAME=gpr12 START=0xC00 END=0xCFF
DATABANK NAME=BIG_BLOCK START=0x60 END=0xAFF
DATABANK NAME=gpr12 START=0xB00 END=0xCFF PROTECTED
#IFDEF _DEBUGDATASTART
DATABANK NAME=gpr13 START=0xD00 END=_DATAEND
DATABANK NAME=dbgspr START=_DEBUGDATASTART END=_DEND PROTECTED
#ELSE //no debug
DATABANK NAME=gpr13 START=0xD00 END=0xDFF
#FI
DATABANK NAME=gpr14 START=0xE00 END=0xE40
DATABANK NAME=sfr14 START=0xE41 END=0xEFF PROTECTED
DATABANK NAME=sfr15 START=0xF00 END=0xF5F PROTECTED
ACCESSBANK NAME=accesssfr START=0xF60 END=0xFFF PROTECTED
#IFDEF _CRUNTIME
SECTION NAME=CONFIG ROM=cfgmem
STACK SIZE=0x1FF RAM=gpr12
#ELSE
#FI
#FI
Task creation
xTaskCreate( Receiver_Tmp, ( const char * const ) “Urt_Rx”, 250, NULL, 1, NULL );
Task definition
static void Receiver_Tmp( void *pvParameters )
unsigned char i;
char bt;
portTickType xUart1Rate, xLastUart1Time;
/* The parameters are not used. */
( void ) pvParameters;
/* Calculate the LED and flash rate. */
portENTER_CRITICAL();
i = 0;
bt = 0;
xUart1Rate = 10;
/* We need to initialise xLastFlashTime prior to the first call to
vTaskDelayUntil(). */
xLastUart1Time = xTaskGetTickCount();
for(i = 0; i < inputRECEIVER_BUFFER; i++)
str_1_ = 0x00;
i = 0;
portEXIT_CRITICAL();
for( ;; )
while(xSerial1GetChar( NULL, &bt, mainNO_BLOCK ))
str_1 = bt;
if(bt == 0x03)
PORTBbits.RB5 = !PORTBbits.RB5;
//Emar_Frame_Analyze( str_1, &cfr );
bt = 0;
i = 0;
i++;
i %= inputRECEIVER_BUFFER;
vTaskDelayUntil( &xLastUart1Time, xUart1Rate );
Queue definition:
xRx1edChars = xQueueCreate( 150, ( unsigned portBASE_TYPE ) sizeof( unsigned char ) );
xCharsForTx1 = xQueueCreate( 50, ( unsigned portBASE_TYPE ) sizeof( unsigned char ) );
Frames which incoming to uart receive come with 38400 bd usualy 20 bytes with gap between consecutive frames 200
Can anyone help me to resolve this problem because my idea was finished now ;(
BR VOLOVIQ_
