devrules616 wrote on Saturday, March 25, 2017:
Hello guys,
So I am new to RTOS . I tried to start with using the Visual studio IDE to build the project.
I created two tasks with following params.
Task1 name="Task1"Task2 name=“Task2”
Task1 stack size = 1000
Task2 stack size = 100
Task1 priority = 3
Task2 priority = 1
started the scheduler.
Now i put two printf statements in each tasks .to check in console. but none of them show up. Please chek the code below .
//1st task that we have
void vTaskCode1(void * param)
while(1)
printf(“This is task 1…%d\n”,i+1);
vTaskDelay(100);
// Create func. for the first task
void vTaskCreate1(void)
BaseType_t xReturned;
TaskHandle_t xHandle = NULL;
/* Create the task, storing the handle. /
printf(“about to create task 1…\n”);
xReturned = xTaskCreate(
vTaskCode1, / Function that implements the task. /
“Task1”, / Text name for the task. /
1000, / Stack size in words, not bytes. */
(int )1, / Parameter passed into the task. /
3, / Priority at which the task is created. /
&xHandle); / Used to pass out the created task’s handle. */
if (xReturned == pdPASS)
/* The task was created. Use the task's handle to delete the task. */
vTaskDelete(xHandle);
void main()
prvInitialiseHeap();
vTraceInitTraceData();
xTickTraceUserEvent = xTraceOpenLabel(“tick”);
vTaskCreate1();
vTaskCreate2();
vTaskStartScheduler();
Any help or suggestion is really welcome. Thank You
