Good day, I’m on a case using FreeRTOS10.3.1 on MSP432P401R, when I use vTaskDelete() , it always go to prvTaskExitError(), I try to use it in blinky_demo from MSP432LauchPad Demo, still the same .
This is the code in blinky_demo:
static void prvQueueSendTask( void *pvParameters )
TickType_t xNextWakeTime;
const unsigned long ulValueToSend = 100UL;
/* Check the task parameter is as expected. */
configASSERT( ( ( unsigned long ) pvParameters ) == mainQUEUE_SEND_PARAMETER );
/* Initialise xNextWakeTime - this only needs to be done once. */
xNextWakeTime = xTaskGetTickCount();
for( ;; )
/* Place this task in the blocked state until it is time to run again.
The block time is specified in ticks, the constant used converts ticks
to ms. While in the Blocked state this task will not consume any CPU
time. */
vTaskDelayUntil( &xNextWakeTime, mainQUEUE_SEND_FREQUENCY_MS );
/* Send to the queue - causing the queue receive task to unblock and
toggle the LED. 0 is used as the block time so the sending operation
will not block - it shouldn't need to block as the queue should always
be empty at this point in the code. */
xQueueSend( xQueue, &ulValueToSend, 0U );
vTaskDelete(NULL);
