egnascimento wrote on Wednesday, November 07, 2007:
Hello friends,
I’m a newbie with ARM development.
I bought LPC-E2294 from Olimex and now I’m trying to use FreeRTOS with this board. I’m using ARM7_LPC2106_GCC example to port to LPC2294. With a few of changes in ld script (to right memory values), the LED position and other little things the code start to work with only “flash.c” uncommented. The others examples was commented like this in “main.c”.
// vStartIntegerMathTasks( tskIDLE_PRIORITY );
// vAltStartComTestTasks( mainCOM_TEST_PRIORITY, mainCOM_TEST_BAUD_RATE, mainCOM_TEST_LED );
vStartLEDFlashTasks( mainLED_TASK_PRIORITY );
// vStartPolledQueueTasks( mainQUEUE_POLL_PRIORITY );
// vStartMathTasks( tskIDLE_PRIORITY );
// vStartSemaphoreTasks( mainSEM_TEST_PRIORITY );
// vStartDynamicPriorityTasks();
// vStartBlockingQueueTasks( mainBLOCK_Q_PRIORITY );
When I uncomment in main routine "vAltStartComTestTasks" or trying to work with a little code using interrupts the program stop to work.
I did a simple test using vectored EINT2 and, when the button in EINT2 is pressed the program stops.
This is the same issue of ISR new implementations for ARM7/9 ports??
All of this tries are using ISR_Wrapper like in the ARM7_LPC2106_GCC examples.
I’ve tried to change optimization (from -O0 to -03) and delete -fomit-frame-pointer but with no changes of this strange behaviour.
I’m working with:
Windows XP SP2
Yagarto with arm-elf-gcc 4.2.1
FreeRTOS 4.6.1
Please, If anybody want take a look at the source code I can send by mail with no problems.
Thanks all in advance,
Eduardo Garcia
